swapping wireing harnesses
Old 10-07-2009, 12:27 PM
demonseed304's Avatar
Car: GMC 1500 P/U 4x4
Axle/Gears: 4:10
I have a 93 gmc 1500 350 4x4 with a blown tbi unit.
Can i swap a Wiring harness from a 84 350 with a carberator and have it work with my 93?
Old 10-07-2009, 12:29 PM
Axle/Gears: 4:10
Re: swapping wireing harnesses
it is being a pain in the ***
Old 10-07-2009, 07:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Sounds like a lot of work for nothing
Why do you need to swap the wiring if going to a carb?
Take TBI intake off , put carb intake on , put in reg HEI dist , run pink ign wire to dist , adj regulator for carb maybe.
You leave all the truck wiring\ computer in place to run the dash and prob the speedo.
Old 10-08-2009, 06:55 AM
Axle/Gears: 4:10
My dist. has an ingniton control modual around the back that is computer controled partially. so how will that work out. It has three plugs in, one comming from the coil, one comming from the computer and one going to the distributor.
Old 10-09-2009, 03:16 PM
Axle/Gears: 4:10
Or would it be easier to connect a carberator with a manual choke
midge54
09-02-2020 07:13 PM
crt454
Interior Parts Wanted
06-23-2017 02:25 PM
TheJoeY88
12-31-2016 07:30 PM
Reddeath210
10-06-2015 08:20 AM
jharrison5
08-19-2015 05:53 PM
Quick Reply: swapping wireing harnesses
