Where is this oil coming from ? PICS
Old 10-08-2009, 10:19 PM
ADMZ24's Avatar
Car: 1991 Trans Am
1991 305 TPI, rebuilt about two years ago. Probably only about 4000 miles or less. I can clean this area up and after a twenty minute drive it reappears on the intake manifold. It is not seen on the passenger side. Any ideas where it is coming from??
Thanks!!
Attached Thumbnails Where is this oil coming from ? PICS-img_3404.jpg   Where is this oil coming from ? PICS-img_3406.jpg
Old 10-08-2009, 10:49 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It's coming around the threads of the intake base mount bolts. Pull them out one at a time, clean up the threads, coat with Teflon paste, retorque, move to the next one.
Old 10-09-2009, 07:22 AM
ADMZ24's Avatar
Car: 1991 Trans Am
Re: Where is this oil coming from ? PICS
Just to be sure, it is the bolts that mount manifold to the heads/block. So I could remove the intake runner on that side for access, then clean, coat, and retorque like you said. Also, how much torque do those bolts get?
Thanks again
Old 10-09-2009, 04:06 PM
five7kid's Avatar
Engine: LS1/LQ4
It's the bolts that mount the intake base to the heads.
25 lb-ft, I believe. Might be 35. Check the shop manual.
Street Lethal
04-30-2019 12:14 PM
Derick15
09-17-2016 05:28 PM
Navy8125
08-21-2015 09:32 AM
86White_T/A305
08-17-2015 12:16 AM
gwade12
08-08-2015 08:17 AM
Quick Reply: Where is this oil coming from ? PICS
