305 Vortec Heads????
Old 03-31-2010, 08:17 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Anyone running a 305 with 1997 or later 305 Vortec Truck heads?? Are they any good?? Will they perform better than the stock 1989 TBI Heads??? I have a chance to get a pair for 75 dollars this weekend..I know the 350 Vortecs flow well, and have good combustion chambers, bit I have not heard anything much about the 305 versions....Thanks, Tom
Old 03-31-2010, 08:22 PM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
Re: 305 Vortec Heads????
You must be careful, some of those '96-up Vortec 305 heads are still swirl-port, just like what you have. They require the Vortec intake manifolds, but they're swirl port. I've had them in my hands, I know this for fact. If you can get an intake valve loose to be sure they're not swirl-port, and if there's no crack in the exact center of either deck surface, then it's okay to buy them. But be aware that these heads don't have the same wonderful short turn as the Vortec 350 heads. They flow the exact same as the heads used with the dual-cat, 5-speed TPI F-cars. But these require the Vortec intake. I've also had these Vortec 305 heads in my little pink paws.
Old 03-31-2010, 08:43 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
This is very useful info. Guess I'll stick with my 416's
Old 03-31-2010, 09:22 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Hey Attila thanks for the "heads" up.....This may sound dumb, but how do you tell by looking if they are swirl port, or not?? I will take a valve compressor with me so I can pop a vale loose...You do not happen to know what the casting numbers are for the good Vortecs do you??? once again, Thanks for the info.So you say the TPI heads are better huh???.Maybe I will just live with these heads..Tom
Old 03-31-2010, 10:35 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Gallileo, if your car has the original LO3, then it has the swirl-ports, which are not performance heads. Also, it'll be really obvious if they're swirl port. 99.9% of newbs can tell the difference correctly, even with no instruction from experts. It's that obvious.
Grumbles or whomever, the '87-up non-swirl heads are better than 416s.
Old 04-01-2010, 03:08 AM
Grumbles's Avatar
I don't doubt it, however I wont be spending any more money on this 305 unless it's upkeep or leak chasing.
Gotta pay down my enormous mountain of debt and save for that 350!
Old 04-01-2010, 04:43 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Do a little search, Fast has dynoed both and reported that the 059 started making more power somewere @4400 rpm up. The 187 made more power in the lower rpms.
Not sure anymore what cam he used, probably the LT4 production.
Old 04-01-2010, 07:35 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks for all the input guys...I have messed with a few 350's, but this is the first trip into the 305 even tho I have had the car for years....Once again, Thanks to all....Tom
Frozer!!!
01-19-2024 04:55 PM
84z96L31vortec
08-20-2017 12:16 AM
bamaboy0323
09-03-2015 06:07 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 305 Vortec Heads????
