Need A Key For My Door Locks... What Can I Do
Old 06-21-2010, 09:06 PM
SSZ2891's Avatar
So i bought my 90 rs v8 camaro a couple months ago. the po said he had lost the key for the doors and trunk. So i keep the car unlocked. now that im gonna start driving it more id like to get a key so i can lock the doors. What can i do.
Old 06-21-2010, 09:41 PM
modern0utlaw's Avatar
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
Re: Need A Key For My Door Locks... What Can I Do
New locks are cheap and easy to put in. The last thing you wanna do is start leaving your car unlocked
Old 06-21-2010, 11:27 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Do like I did...............Take it to a locksmith!
$30 bucks and I had the correct keys for all the locks/t-tops
Old 06-21-2010, 11:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
https://www.thirdgen.org/forums/tech...keys-need.html
Old 06-21-2010, 11:37 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
replace them they're cheap
Old 06-22-2010, 12:12 AM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
wow, lol, my thread got attention even in here lol
Old 06-23-2010, 09:21 AM
Hydra_Shock's Avatar
$17 for a new key at the chevy dealership. Will work on your doors, hatch, and t-tops (if you have them). (I just bought me a new key).
Take your title to show ownership, and they will use the VIN number to lookup the key code. (Hope your locks are factory)
Old 06-23-2010, 10:58 PM
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
That's how I got my keys replaced, the dealership also gives you the same shiny round key that came stock with the car
Old 06-24-2010, 07:43 AM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
Your better off just replacing them because the old factory locks on mine were corroded and snapped right off when I hit it with a screwdriver. That really woudln't stop anyone from breaking into the car
Old 06-24-2010, 09:28 AM
Lasalt's Avatar
Car: 1991 Pontiac GTA
Engine: 5.7 350
Transmission: Automatic
i had a 90 GTA about a year ago my dad had lost the keys and all i did was spend 10 bucks and got a new ignition key and door key. So i would do that before replacing the locks... Just my opinion, and the parts guys at the dealerships always get excited when you pull up in a third gen
Old 06-24-2010, 05:42 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
I am a certified locksmith. A new door or hatchlock key is not an expensive proposition, even a VATS ignition key or lock cost much anymore. Go to a locksmith or dealer, it should not cost more than $10-$20 for replacement keys, or double that for new locks, if you replace them yourself. Randy
Old 06-24-2010, 06:07 PM
mos68x's Avatar
VATS ignition locks are $47 at Advance Auto for mine (91) I'm sure that it wouldn't cost much different for yours unless they are non-VATS. Door locks were only $13.
tglennon11
09-23-2015 05:30 PM
billybob6110
09-23-2015 01:30 PM
tsfso59
Exterior Parts Wanted
09-09-2015 09:09 AM
Gunsbee
09-07-2015 07:10 PM
SG91camaro
09-05-2015 10:27 PM
Quick Reply: Need A Key For My Door Locks... What Can I Do
