low oil pressure
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
low oil pressure
yesterday my oil pressure gauge started reading really low. it normally idled at 30 psi and would climb to 60 with throttle. now it barely reaches 30 with throttle and idles just above the red"warning" zone when warm. i checked the oil and it was right where it is supposed to be. i just started running 10w40 high mileage oil in her with my last oil change. what do u think could be causing this issue?
thanks
eric
thanks
eric
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
Re: low oil pressure
Change the oil pressure switch on the engine block beside the oil filter. These are known to go bad often on these cars. I think it's around $18.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
If you don't see any improvement with the new oil pressure sender try a mechanical gauge. Or just go straight to the mechanical gauge, that's what I did in my Camaro. I have a mechanical temp gauge too cause I was having issues with that one reading incorrectly as well.
You could also try changing the oil filter. If its clogged it can cause pressure problems.
Next step would be replacing the oil pump.
If none of those get it back up to normal you're probably looking at a rebuild. Had the same thing happen twice on my truck.
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
A bad oil pressure sending unit does exactly what you explained. When mine was bad it would sometimes go to 0 in dead of winter.
Car: 1986 IROC
Engine: 355" TPI
The sending unit is very likely since it happened all of a sudden. swapping the oil filter is not a bad idea either. There is a chance it has had a failure. If it continues after you replace the parts then get a cheap mechanical gauge and temporary connect it for comparison. If they agree just keep an eye on it. I have seen several people change oil pumps in older engines just to be disappointed because the pump is not the only worn part. If the pump has worn out its likely that the bearings are also done.
Car: 1992 Camaro RS
That's exactly what happened with my truck's engine. Swapped the oil pump and it worked for about a week and a half before the pressure dropped back down again. When I finally tore the engine down, EVERY bearing was shot and the crank and cylinders 7 & 8 had some nasty scoring. The cam bearings had NO bearing material left on them, just the base steel behind the bearing surface. Surprisingly the engine ran really well though.
Car: 1990 Iroc Z
Engine: 355
It's just very easy labor-wise, time-wise, and money-wise to spend the $18 and take a shot at changing the pressure sensor before you get carried away pulling your hair out worrying about a re-build. IF you did have a bad oil pump, I would never just change the pump if I had the motor already out. It'd be SO worth your while to re-ring and put new bearings on the crank, rods, and cam while it was down and easy to get to.
I'd still put my money on the sender since pressure changed on you quickly.
Car: 91 rs
Engine: 305tbi
is the sender by the oil filter? if so how did you manage to get a wrench down there to remove the unit. it looks to be over an inch in size and there is no room to work it loose. any tips?
thanks
eric
thanks
eric
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
First thing is to replace the sending unit. They frequently fail and are relatively cheap to replace. You may also want to confirm the reading by using the port on the back china wall and a mechanical gauge.
*****Ignore my comments. I thought I was the first person to respond but obviously the topic has been well covered********
Car: 1992 Camaro RS
Car: 84 Z-28
Engine: 355 4 bolt main
Transmission: 700 R4
Axle/Gears: Posi 3.73
Replacing the oil pump is do able if that is the problem, but it is a pain. Those other guys are right if that's the case you will probably soon discover after start up your cam bearings are gone. If you pull the pan and there is a bunch of black gasket looking stuff in the pan the bearings are gone. Good luck probably is the oil sending unit though.
Car: 91 rs
Engine: 305tbi
got the sending unit replaced. was a real PITA to get to tho! thanks
eric
eric
1 Post
Car: 90 camaro rs
I had to get mine from underneath and used a pair of channel locks and just turned it a quarter at a time
Car: Pontiac FIREBIRD
Engine: 3.8L
On topic here, I just recently changed the oil pressure switch because it was leaking. After that I get 0 oil preassure while a complete stop. 30 with WOT. Before replacing the switch I would get 1/4 of the gauge at a stop light 3/4 on a good day. Engine feels strong though. will be getting some gauges today. Thanks third
Car: 1992 camaro rs
Engine: 305 v8 tbi
my thirdgen 92 camaro dropped oil preasure today while at an idle and all the oil pump and oil sender is new as i just rebuilt the engine not sure what might have happened after the car cooled off i started it again and the oil preasure was back up where it is suppose to be any suggestions would be great feel free to pm me or answer here thanks
Car: 1989 Camaro RS
Engine: LO3
I just had the same switch to replace and I want to share the way I finally got it out. Save yourself some time and use a mini hack saw and cut off most of the old switch so you can get a 30 mm socket on it and it will be out in 10 minutes. I fought trying channel locks, pliers, wrenches. There's no room. I wish I had done this first. Switch was $40 and socket $10. Ouch
ambainb
04-25-2016 09:21 PM
