Questions on Starters
Old 11-15-2010, 11:14 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Okay here is what I know, and what I am trying to do.
I know that there are 2 bolt patterns when it comes to SBC starters, straight ,and staggered bolt holes. I know that the straight bolt patterned starter goes with a flywheel that has a different number of teeth than the one with staggered bolt holes. You can't interchange the starter with the wrong flywheel, or they will bind.
Here is what I need to know:
If I have a SBC with a flywheel that takes the straight bolt pattern starter, and needed to use a starter that has the staggered bolt pattern, would it be possible to swap out the gear from the straight starter and use it on the staggered starter to work that way?
Thanks!
Old 11-15-2010, 11:30 PM
Re: Questions on Starters
I found this starter which seems like it would work with what I am trying to do, but WOW that price is steep!
http://www.summitracing.com/parts/CSI-100PSBP/
Old 11-16-2010, 03:58 PM
Anyone ever done this?
Old 11-16-2010, 08:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No
Don't understand your " needed to use a starter that has the staggered bolt pattern,"
Starter has to match flex plate being used ; period
How the starter bolts to block sets it's relationship with flywheel
Try this one for 153 tooth flex plate ( straight starter pattern)
http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories
Old 11-16-2010, 09:49 PM
There is a bolt broken off in that spot, thats why I was trying to use a staggered starter. The gears will not inter-change?
Old 11-16-2010, 10:30 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ok that's wat i wana kno also if u can change the gears also...changethe gears off a starter that fits a 163 fly wheel 2 a starter that fits a 153 teeth fly wheel...
does anyone kno whats the correct number of teeth on a 83Z28 camaro 5.0 fly wheel?...
Old 11-16-2010, 10:58 PM
I read that they both have 9 teeth, just a different diameter.
I have a straight starter laying around, but no staggered starter, otherwise I would just try it myself.
So they will not interchange???
Old 11-16-2010, 11:21 PM
Car: 1983 Z-28
Engine: 5.7 L
o ok...i had to put a staggered one on mine...bcuz the straight one wont fit with my t5...:/..
Old 11-17-2010, 12:07 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
.change the gears off a starter that fits a 168 fly wheel to a starter that fits a 153 teeth fly wheel...
Is nothing to do with the gear size ; is to do with the position of the gear in relation to flex plate
Bolt pattern is different to move starter ( and gear ) further away from the block to fit the larger 168 tooth (14"dia ) flex plate
153 is only 12 3/4" dia
IIRC the drive gear ( bendix ) is the same unit on both styles; in fact the two types of starter are identical EXCEPT for the offset from having a different bolt pattern on the starter nose
Old 11-17-2010, 12:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Get the right extractor ,
http://www.summitracing.com/parts/WMR-W2966/
take broken bolt out; problem solved
Old 11-17-2010, 12:22 AM
Car: 1983 Z-28
Engine: 5.7 L
ok...so i can put a straight starter on my t5 instead of the stagger one?...
Old 11-17-2010, 05:51 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What size flywheel do you have?
Starter MUST match flywheel
Most blocks are drilled to take both style starters but only one will be right for your flywheel
Old 11-17-2010, 09:17 AM
Car: 1983 Z-28
Engine: 5.7 L
ok my block is drilled 2 fit both...my fly wheel has 153 teeth...or do i need 2 get the one that has 168 teeth?...
Old 11-17-2010, 06:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So you need a starter to suit that with straight bolt pattern
If you change to 168 FW, you need a starter with staggered bolt pattern
Old 11-17-2010, 08:28 PM
So it cannot work, allright, thanks!
Old 11-17-2010, 09:41 PM
Car: 1983 Z-28
Engine: 5.7 L
i have 153 teeth FW and i cant fit a straight bolt pattern in it so i have to put a staggered bolt pattern on...
Old 11-17-2010, 09:50 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
well hope you dont mind me bumping in to your thread . now my problem is i got headers on my camaro so my stock starter dont fit any more so i got a starter out of a 96 truck 5.7 and and 2 days later the housing broke does any one have any idea y it happen?
Old 11-17-2010, 10:31 PM
slapstick's Avatar
Car: 86 Camaro z/28
Engine: running gear from 88 firebird
Every once in awhile my starter spins freely and doensn't catch on the flywheel. It's starting to happen more and more and getting annoying, any thoughts?
Old 11-18-2010, 03:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
i have 153 teeth FW ..so i have to put a staggered bolt pattern on...
So it ain't going to start then
i cant fit a straight bolt pattern in it .
Why not?
Old 11-18-2010, 04:06 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Most likely the spring in the Bendix drive ( the part with the gear that engages flywheel ) is weak from age
# 2 in pic
The solenoid pushes the gear out fine but if the spring is weak then gear doesn't always come into contact with teeth on FW
Also check teeth are not worn on FW ;common to wear in one spot where starter always engages
Frozer!!!
01-19-2024 04:55 PM
Caspar
06-19-2016 11:19 PM
Cleotiz
08-22-2015 01:54 PM
redmaroz
08-16-2015 11:40 PM
milk
08-10-2015 06:26 PM
Quick Reply: Questions on Starters
