4 in stroke crank in a production 2pc 350 block?
Received 1,666 Likes
Re: 4 in stroke crank in a production 2pc 350 block?
Yes
It is extremely difficult, to the point of being not worth trying unles you have access to a large pile of blocks to keep trying on until you accidentally fail to scrap one.
About the longest stroke customarily used is 3.875", which is referred to as a 396 when the block is .030" over.
Yes
how much clearancing would I would have to do to fit a 3.875 crank?
any risk of hitting water?
filling the water passages with something to fit stroker cranks any thoughts on this?
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
I had a 400 with a 4" crank in it many years ago. I used a Cam Motion cam, small base circle, which is a must. I used Oliver 6" stroker rods and still had to grind a few of them for cam clearance. The lower part of the block was filled with Hard Block, a filler thats like concrete, that stiffens the cylinders. Also had splayed main caps. It made pretty good power for a 23 degree head engine. Best I can remember it made 670 ish HP on Gene Fultons dyno.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
no help as to how its done, but my sbc has a 4" stroke in a late model vortec block, 94 i think? Its a crate engine, came built that way, not sure how it all fits. no block filler or any of that jazz
Engine: LS6
Are you sure about that? I thought the big inch gen 1 small block crate engines were the 383 & 400. Both use a 3 3/4" crank. I didn't know GM even had a 4" small block crank, aside from the LS type engines.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pushing it to 4" in a stock block is possible but difficult. Clearancing at the bottoms of the cylinders needs to be done. A small base circle cam needs to be used. Special pistons need to be used which moves the wrist pin up into the oil rings and have enough cut away from the bottoms of the pistons to clear the crank weights.
For what it's worth, it's better to use an aftermarket block. Raised cam, taller deck etc.
Engine: LS6
Sorry if I misled, this was NOT a street engine. Drag race only.
When I was asking my machinist friend about how much stroke a sbc would take he said some 1 piece blocks would take more stroke than a 2 piece. I think I remember seeing 4 inch stroke small block cranks in the 2nd or 3rd edition of the chevrolet power book from the 70's/80's so gm may have made them just not in any production engines.
Engine: LS6
Thanks for the replies. I'm going to price out an aftermarket block etc. a big block/LS motor is starting to look better and better for the power levels I'm looking for.
Car: 87 IROC L98
Don't forget that trying to build a big small block runs into other problems. A good set of high flow small block heads can get expensive to feed a big engine while a basic set of BBC 781 heads with a port and polish and bigger valves can do the same thing for a fraction of the cost. The BBC can get more potential with better than stock parts.
Bottom line is, if you want a 400-inch SBC, go to the junkyard and get a 400. Cheeeeeeeeeepest and eeeeeeeeeeeziest way to get there, by far.
Think I'm gonna go for a big block. Is there a serpentine setup for a big block that will fit in these cars? will I need a cowl hood? I would really like to keep the stock hood if possible. it looks like an hei is'nt gonna fit am I correct about this? can I make one fit? can I use a tall deck block?
Car: 87 IROC L98
Tall deck block has a lot of clearance issues.
HEI will fit with no problems. I ran one for a few years. The back of the block is the same distance away from the firewall as a SBC. The extra length of the block goes forward.
Unless you use a real low profile intake manifold which will hurt performance and use a drop base air filter, you're going to need some sort of cowl for clearance.
Finding a 400 SBC in the junkyard is getting hard. There hasn't been one made since 1979 so finding a 70's vehicle with one in it is getting harder and harder.
There were no serpentine belts for the BBC, or at least no reverse rotation water pump systems until 1991 when they switched to the Gen V engine but there are plenty of aftermarket systems that will work. My 91 454SS uses a serpentine belt system.
my 408 is a 350 vortec block with a 4" stroke, crank and rods are K1, mahle pistons
theshackle
03-05-2017 06:37 PM
