92 No Start
Old 04-11-2011, 05:39 PM
Kroyster01's Avatar
92 No Start
I have a 92 RS 6 cylinder. I put the key in and all the lights come on just as they should. Radio, dash lights, everything. I hear the fuel pump coming on as well. Turn the key and nothing. No clicks, no nothing. I tried having a friend hold it over while I banged on the starter and nothing happened. I tried wiggling the wires to the ignition switch and nothing happened. Tried disconnecting and cleaning the battery terminals and nothing happened. This is my daily driver and I'm in need of some help here. Thanks folks.
Old 04-11-2011, 06:39 PM
Kroyster01's Avatar
Re: 92 No Start
Also, the security light never comes on, and the INFL REST light comes on and stays on...
Old 04-11-2011, 06:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 92 No Start
is it in Park?
Old 04-11-2011, 06:47 PM
Kroyster01's Avatar
Re: 92 No Start
Yeah I tried shoving firm into park as well as neutral.
Old 04-11-2011, 07:15 PM
Car: 1992 RS
Engine: Carbed 350
Re: 92 No Start
Might still be a VATS issue even though your not getting a secuity light. Find the starter enable relay, and remove the relay, then take a short piece of 10gauge wire, and stick it in the relay connector so that the large yellow and large green wire are connected, then see if the starter turns. If it does, then you know you have a VATS issue and you need to bypass the VATS.
Old 04-11-2011, 08:22 PM
Kroyster01's Avatar
Re: 92 No Start
I was thinking vats, just because the bypass hasn't been done yet. I didn't think about jumping the starter relay though. Would it still be able to be jumped even though the vats has it disabled? Do you know where it is located?
Old 04-12-2011, 05:38 PM
Kroyster01's Avatar
Re: 92 No Start
Just an update. It was indeed the Vats, even though no security light came on. I did the bypass but I didnt have to cut any wires. Instead I just bent a 10k Ohm resistor into a horseshoe shape and put it into the Vats Module side of the connector, and electrical taped it up. Fired right up the first time. Took 2 minutes and less than a dollar. Hope this helps somebody.
Old 04-12-2011, 05:55 PM
Car: 1992 RS
Engine: Carbed 350
Re: 92 No Start
Glad it worked out
Orr89RocZ
04-25-2016 08:28 AM
Wade787b
09-29-2015 01:15 PM
SolarGoldRaptor
Carburetors
16
08-25-2015 02:25 PM
92camaroJoe
08-13-2015 06:07 AM
86Base
08-08-2015 01:34 PM
Quick Reply: 92 No Start
