clean 1989 irocz overheating issues
Hey im new on here but i just bought a really clean 89 iroc with a tpi 305, with new radiator, thermostat, and water pump but after driving a few miles it starts to overheat so i was thinking it was the headgaskets does anyone know anything that could help me with it.
Received 1,662 Likes
Re: clean 1989 irocz overheating issues
Define "overheat".
Tried a new radiator cap yet?
The fans work?
Sure it's the right WP? That car should have a serpentine system, which turns the pump backwards; putting the pump for an older car on there will pretty much guarantee weak coolant flow at best, usually not adequate, since even though it's a centrifugal design and therefore moves the fluid the same direction no mater which way it's spinning, the blades are MUCH more effective when going one way than the other.
The fans work?
I havent really checked out the serpentine system but the car smokes when i start it so i believe its burning oil leading to a head gasket or some other gasket maybe intake or exhaust?
Is it just a puff? If so, then it's just valve stem seals. Not a big deal. You can just ignore it for years if you want. Should be blue smoke.
If it continues to smoke after that, and it's whitish smoke, then maybe it's a headgasket.
mdtoren
08-16-2015 05:45 PM
