305 Tune up
Old 06-17-2011, 10:17 PM
Wood{USN}'s Avatar
Car: 91 Rs Camaro
Engine: Stock 5.0L 305 in need of some love
Transmission: Stock
Axle/Gears: Stock
305 Tune up
Finally taking the time and money to get my 305 running worth a crap now. heres my plan. Going to replace spark plugs, wires, distributer, alternator, take out ac compressor (ac is shot anyway) replace with a delete pulley, new gaskets on everything, new belts, , fuel pump/filter and new brake booster and master cylinder.... did i forget anything?
Old 06-18-2011, 03:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 Tune up
I wouldn't touch the brake booster, the master cylinder, or the fuel pump unless you are having issues.
If you are getting fuel, then the pump is fine - they either work or they don't.
Brakes - spend cash on new rubber lines - there are 3, 2 front and one rear - makes a great great difference in stopping power. Do pads also if needed.
Wouldn't do a complete distributor either - just a cap/rotor. Might replace the ignition control module inside the distributor if you like - they do go out on occasion.
Definitely wires, plugs. Vacuum lines that are worn/cracked need replaced.
That will save you $200 - $300, and get you finished in an afternoon rather than a weekend!
Old 06-18-2011, 08:57 PM
Wood{USN}'s Avatar
Car: 91 Rs Camaro
Transmission: Stock
Axle/Gears: Stock
Re: 305 Tune up
Need a new booster, its gone i have no vacuum on the brakes. (on the plus side ive gotten in iron leg getting use to having to braking support)
And im guessing the fuel pumps about to go. it almost wants to die. unless i floor it then it sputters almost dies and goes like a bat out of hell after that. or would that be the filter/ line clogged somewere. was planning on replacing the whole starter and ingnition system. previous owner has "something" rigged i havent seen before but its now a push start and that seems to want to die. it wont crank unless i finger "****" the button until it lights off. hadnt thought about rubber brake lines, do you have a good recomendation for some?
Old 06-18-2011, 08:59 PM
Wood{USN}'s Avatar
Car: 91 Rs Camaro
Transmission: Stock
Axle/Gears: Stock
Re: 305 Tune up
Jake_92RS
01-28-2020 10:37 PM
Street Lethal
04-30-2019 12:14 PM
Fast355
12-02-2016 06:33 PM
theurge
08-21-2015 12:46 PM
ezobens
08-19-2015 10:29 PM
Quick Reply: 305 Tune up
