carb car wont start grr please help
Old 06-22-2011, 12:17 AM
affliction1's Avatar
Car: 89 chevy camaro rs
89 CAMARO 305
i pulled the motor to do pan gasket and chain,detent cable,took a/c stuff out
car is getting fuel
starter spins
and spark(timing light)
is at tdc pretty sure(timing light flashed when mark on balancer showed 11 degrees on timing tab
some one please help me fast
Old 06-22-2011, 12:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb car wont start grr please help
What kind of carb? You replaced the timing chain? Did you have the distributor out?
Old 06-22-2011, 01:06 AM
carb isnt prob didnt touch it or flip it just removed and layed aside,did remove distributor,but pretty sure i put it in right,timing light flashed close to 11 degrees on timing tab,and i made sure to line the rotor and the num 1 spark plug connector up on cap and when i was rotating car to tdc,i checked that both rockers on no.1 cyl were loose to confirm tdc any ideas
Old 06-22-2011, 01:08 AM
maybe 180 off due to having tdc on exhaust stroke?
Old 06-22-2011, 01:10 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably
Old 06-22-2011, 01:14 AM
oh man...lol it is 180 off...when timing the exhaust valve was just closing which means the intake was about to open,sorry for wastin time
Old 06-23-2011, 12:56 PM
so to get it back to compression stroke can i gett it at tdc on exhaust stroke,then pull dist. out spin crank full 360 untill timing mark lines up again(will it be on tdc compression stroke?),and drop dist in ,then gett it timed.also whats the factory timing for a 91 305
midge54
12-27-2019 04:14 PM
Azrael91966669
25
06-20-2017 04:04 AM
theshackle
03-05-2017 06:37 PM
Wade787b
09-29-2015 01:15 PM
86IROC112
08-17-2015 02:00 PM
Quick Reply: carb car wont start grr please help
