Tubing to AN adapter. How does this work?
I am running the earls tubing to AN adapter fitting on the top of my tank to run braided fuel line. I have the fitting and I'm just curious as to how I assembly this piece. Does anyone have experience with these? I don't want to mess up the fitting. I've never worked with these before. I've seen some of you use them in the past.
Thanks,
Thanks,
Re: Tubing to AN adapter. How does this work?
http://www.summitracing.com/parts/EAR-165106ERL/
This is the fitting. I'm just curious on how to install it and how it works.
Thanks,
Thanks,
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
thats what i used on my dual intank pump writeup, there is a small compression piece not pictured. I have been using mine for over a year now without any problems, some people said it was going to leak but so far so good for me, i have a blow through carb so i dont see more than 20psi of fuel pressure at full boost.
btw i just pm'd you back
Street Lethal
08-13-2015 08:28 PM
Street Lethal
08-12-2015 11:33 AM
