Trouble Starting the IROC.
My IROC would turn on fine and immediately until a week ago. It slowly progressed. The problem is that the Camaro has a hard time turning on. I can crank it for about 5 - 10 seconds and it starts to sputter but doesn't start. Now as I crank it again, it'll sputter and turn on. Has anyone had this issue? I have a 2 year old stock coil, 21 lbs Bosch III's injectors, Durolast plug wires, AutoLite Spark Plugs, Duralast IAC valve. The IAC was loose but I re tightened it but to no avail. I turned on the IROC at night to see if there was a stray spark but nothing. All seems fine other than the hard start. Oh, the FPR is about 2 years old. There are also no trouble codes. Can it be a bad 9th Injector? Thanks in advance guys.
Car: 1990 Mazda B2600i Cab Plus L98 Swap
Engine: 5.7 TPI, LT1 cam, 24 lb. Inj.
Transmission: BowTie Overdrives Level 2 700R4
Axle/Gears: 3.909
Re: Trouble Starting the IROC.
I am having the exact same problem, but mine is L98 without a cold start injector.
Sometimes I have to crank, wait, crank, wait, crank, wait, crank... Oh, it started!
I have a new ignition module, idle air control valve, 24 lb. Bosch III injectors, fuel pump and pressure regulator.
My fuel pressure at startup is 40 psi.
My problem only happens at first startup, or after sitting for an extended period.
Starts and runs fine when warm.
That is the same damn thing that is happening to my Camaro. My FPR is 2 years old, the FP is 2 years old too. The guts of the HEI Dizzy is 1-1/2 years old. I got 21 lbs Bosch III injectors. Im gonna try a Fuel Pressure test to see if I have the proper fuel pressure. My Fuel filter is got to be atleat 10 years old but Ill see what happens when I change it. Its too hot to work outside where i live. Right now its 104*.
Relay?
MAF relay
MAF Burn-Off relay
Fuel pump relay
Hatch release relay
Fog light relay
A/C blower relay
Power Antenna relay
Nope. I don't think its either one of those relays. My MAF, MAF Burn-off, and Fuel pump relays are also 2 years old.
MAF relay
MAF Burn-Off relay
Fuel pump relay
Hatch release relay
Fog light relay
A/C blower relay
Power Antenna relay
Car: 85 Z28
Engine: 327
Fuel pump relay could be bad. I had same problem with truck. Have to take it out and tap it to reset it. Worked. Have to do it anytime it get to hot or if it sits for to long.
Im not sure if my fuel pump relay has the resistor inside. I had a similar problem with my A/C blower motor relay. It wouldnt stop when I turned off the IROC awile back. So I had to tap on it to release the mechanizm within. Some relays contain a small resistor to prevent the relay from welding itself in a close circuit. This resisstor prevents the "arching" when the relay enters close circuit. But right now its a guessing game. So tomorrow im gonna rent a FP gauge to verify that I have the proper pressure.
Car: iroc z
my car acted up like this for over a year. replaced everything but the motor itself. ended up being a clogged up conveter
Just got done performing a fuel pressure test. For the prime, the pressure went to 49 lb. While cranking, the pressure was agian at 49 lb. While idling, the pressure was bouncing up and down at 39-40 lb. Im gonna look around to see what pressures I should have.
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Does it hold the pressure or does it bleed off right away?
Could be a bad cold start injector...
Maybe a bad or shorted coolant temp sensor.
I just read my Haynes repair manual and it says that normal pressure range is 34-47 psi. While idling the pressure should drop atleat 3 - 10 lbs below the piming pressure. So with that said, I am 2 lbs over the maximum range and Im right on the money while idling. So my fuel pressure is fine. Im gonna check the resistance of the injectors later when it cools off.
Car: 1986 IROC
Engine: 355 Tpi
I'm not sure of the resistance, I'll have to see if I can find my shop manual when I get home.
I had a coolant temp sensor say it was at -20F when it was 80 degrees outside, but it didn't set a check engine light. Made the car hard to start, but it ran rough too.
I was reading another thread that starting issue can be related to a "Cold Start Injector Switch". Im gonna have to pull the CS injector and crank the engine. If there is no fuel coming out of the injector, then either the CS injector is bad, or the CS Injector Switch is bad. This sux man. The whole time I thought it was my IAC valve. But that works fine.
Well the ninth injector is around $120. Let alone that a memcal runs about $100. Also with shipping. Hell, it all comes down to about the same. Would there be a difference between a 87 memcal and the 89 memcal other than the 9th injector? I do know that the 89 spits more fuel through the injectors at start up. But what else is different?
Axle/Gears: 3.909
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Hmmm, plug gap, timing, is it getting a good spark? Make sure the TPS is set right and working correctly.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
My buddies Trans Am has the same issue. We replaced the Distributor, Plugs, Both Relays, Fuel Pump, IAC, Injectors, Fuel Pressure Regulator, MAF... and I am prob missing a few things... It just cranks for like 10 seconds then starts. If it is really cold though, it won't start at all. We are lost what to do. Sounds like the same issue we are having.
I recently had a 92 RS TBI that would do similar things, long crank then rough run when finally started. In cold weather it was worse than warmer weather and it ended up being a fuel pump relay. It wouldn't start until it finally got oil pressure then it would fire the injector and start. Eventually it wouldn't start at all unless you primed it and at that point the oil sending unit had went out also, no oil pressure reading, no start!!!
Wait a minute!!! I could be the oil pressure unit. If there is no oil pressure, it'll will not close the circuit to feed voltage to the fuel pump. Damn. I forgot what is on that little splitter tube behind my dizzy. There is the oil pressure sending unit and something else. I just can't remember what it is. Perhaps that's the problem. There is one other way to get the engine started fairly quick, starting fluid. Works every time!
Car: 1989 IROC-Z
Nah, I have my oil pressure sensor unplugged. Had to unplug it due to it wanting to run my fuel pump all the time. It could be different for cold start systems though.
Car: 1989 IROC-Z
LOL, funny you say that! I had just taken my harness out to replace all of the plastic conduit and fix some bad spots when the sensor went out. Theres a lot of conflicting info about the oil pressure sensor. On one hand, it's supposed to cut fuel when there is no pressure, on the other you can unplug it and the car will still run. So to answer your question, there is no splicing in my harness, thank god!
Okay guys. I got some injector resistance results. My injectors are the Bosch III 21 lbs. So here we go....
Injector/Cylinder #
Injector/Cylinder #
- 15.8 ohm
- 15.8 ohm
- 15.9 ohm
- 15.8 ohm
- 15.8 ohm
- 15.6 ohm
- 15.7 ohm
- 15.7 ohm
- (Cold Start Injector) 4.4 ohm
Here is a video of my start up. I recorded the fuel pressure on prime and during start up as well. Notice that it is a bit hard to start up. But Ill get another video of it starting up while "cold". Other than that, is this pressure common?
http://www.youtube.com/watch?v=E_BbCaJ43w0
Axle/Gears: 3.909
Mine started just like that when cold. Once it fired up the first time, it started fine afterward... until the next cold start.
By chance, I found the solution to my problem.
I ultimately developed a misfire, and narrowed it down to an injector.
When I pulled the fuel rail up found some jellied substance in my #8 injector.
While I had my upper plenum out, I decided to install my adjustable fuel pressure regulator.
When I pulled the diaphragm out, to purge the jelly out of the fuel rail, I saw that half of the area under it was full of what appeared to be crystallized honey.(I wasn't sabotaged)
This stuff was as hard as carbon buildup on an exhaust valve.
After I re-opened the port from the right side fuel rail, and cleaned it all out, I reassembled it and she fired right up!
Been starting fine ever since!
fuel pressure looks good, Is this only on cold starts?, or all the time?
I have a simular problem with my 87 that I am still working on. I unplugged
my cold start injector for testing purposes & mine sounded just lke yours when I tried to start it.
I noticed that you mentioned that you have an 87. Would I interest you in a copy of the 1987 GM Camaro Shop Manual? If so, just click on the 1987 below in my signature block for further details.
1 Post
Car: 1992 convertible camaro 1992 z28
Engine: 305 tbi 5.0 tpi
Transmission: 700r4 700r4
Axle/Gears: 2:73 2:73
hi did you fix the problem the same thing is going on with me
Mine, I am going to have to live with as I have for the past decade
Ruled out just about everything, But I am fairly certain its fuel related. If I spray
just a smidge of starting fluid in the airbox right after I fire it cold, it will run perfect.
Cold start injector checked out fine. But for what ever reason my car doesn't get enough fuel for the first 8 seconds after startup. This only happens when its at room temperature & been sitting afor 8+ hours.
At some point I will see If I can find someone that I can swap ECM's with, just to rule that out.
#42
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Thats exactly the way my car acted when the fuel pump started going. The pressure would bleed off like that once I turned the car off. It ended up being a bad check ball in the pump. Replaced the pump and it has been PERFECT ever since. Although I do have a slight hard start problem, but its because my distributor is on its way out.
#43
Should the fuel pressure be higher at cold starts? I have 45psi at all times. It does bleed off pressure after the inital prime,(10+ seconds) but jump right back up to 45 the second it starts no matter if its a rough cold start or a smooth warm restart.
#44
Car: 1988 Iroc
Engine: 5.7L
Nope, It should not be higher. It should bleed off, but not after 10 seconds. That means something is off, although I know people whos cars do that and they dont have any problems.
FWIW, my car with a new injectors, regulator, o rings, pump etc will prime to about 43ish psi and stay there after the key is turned off for a while. its down to about 25 after 1hr and damn around 5-10psi after that 2nd hr. This is on a completely stock 77K motor with just the free mods.
Prior to doing my pump, it never blead down faster than I described before, but when it started giving me running problems, thats when I notice it bleeding down about as fast as you and the OP describe.
There is a way to check if your pump is bad or on its way out, Ill have to search for it, but its something like clamp off the return line, prime your system and if your fuel pressure shoots up into the 60+ (maybe more, i forgot) range then your pump is good if not, it can be bad. I did this trick AFTER replacing my pump and got something crazy like 95PSI, then once the pump shut off it blead down to 43psi and stayed there.
#45
Car: 1989 IROC-Z
Coolant temp sensor will give cold start problems as stated above. Fuel pressure shouldn't bleed off too fast, depends on the pump, but it should take a while for the presure to fully bleed off. Could be a sign of leaking injectors. I solved my hard start problem by swapping distributors, got bored and figured it was worth a shot lol. Check your spark plugs and their gap, you might want to prime the fuel pump and let the pressure bleed off, so when you're checking the plugs you can see if they are wet from fuel.
#46
#47
Car: 1989 IROC-Z
HAH, I've read that a few times and never realized that, DUH!! Boy, I feel dumb for handing out advice I've never tried myself or thought through. Vacuum leaks will also cause longer start up's, my car just started doing it out of nowhere one week, as I was about to pull the CTS out I notice e line that plugs into the bottom of my throttle body had came off, plugged it in (with a drop of glue) and started right up! Nope, still feel dumb.....ugh.....
#49
Car: 1989 IROC-Z
Oh I know, I'm still lughing at myself for it though. It's not like I suggested removing the transmission to change the fluid.
