With 383, How much power will I have - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 09-06-2011, 07:46 PM   #1
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Well I rebuilt the motor over the winter and after 3k in parts and etc I blew the motor on the dyno. Havent torn the motor nor will I be since my dad is mad haha I think I broke a lifter and blew a headgasket since the exhaust was not opening on cylinder #1. Coolant got in oil and was running for a little bit bearings are unknown and car runs on around 5-6 cylinders. I want to make it a 383 now stroker so heres what I have done so far.
Comp 503 cam
Patriot 190cc Aluminum heads
1:6 roller rockers
7/16 pushrods
Headman headers
Stealth Ram Intake
30lb fuel injectors
Holley Fuel rail
Walbro Fuel pump
Cap and rotor
8.5mm wires
stock pistons
3:73 rear gears
I want to stroke it and wonder how much hp I should have around and 1/4 mile times.
87IROCZCamro is offline vBGarage Page   Reply With Quote
Old 09-06-2011, 08:35 PM   #2
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: With 383, How much power will I have
you need to give the combustion CC's ???
Headman FL or shorty??? what about the rest of the exhaust???
2 or 4 valve relief pistons ??
"7/16 NO" pushrods, FP, cap, rotor add nothing
zero deck 383???
gasket thickness???
so far I'll give you 360 - 400 <> 12 range 113 - 116
88gta3508 is offline vBGarage Page   Reply With Quote
Old 09-06-2011, 11:35 PM   #3
Car: 1983 Camaro Z28
Engine: 383
Transmission: TH-350 w/ transbrake
Axle/Gears: 4.11 Moser 9 inch Detroit Locker
What kind of times do you want from the car that is the better question
izcain is offline vBGarage Page   Reply With Quote
Old 09-07-2011, 12:43 AM   #4
Transmission: 700r
zero deck 383???
gasket thickness???
To be honest I do not know right now. I am taking to a shop that will deck and block and heads and I know the fp cap etc add nothing was just noting for what i have in the car.
I want the car to run low 12s if possible with a 383 mid 11.
Thread Thread Starter Forum Replies Last Post
91 camaro starting issue 5spdcamaro Tech / General Engine 1 08-28-2015 03:12 AM
Power adder section needs a new mod sailtexas186548 Problems / Help / Suggestions / Comments 2 08-24-2015 11:11 PM
Wiring my starter Accerrito22 Electronics 3 08-23-2015 08:22 PM
Project Torched 2.0? 86White_T/A305 LTX and LSX 0 08-17-2015 01:16 AM
Strictly Out of Curiosity sreZ28 Engine Swap 4 08-14-2015 08:48 PM
Go Back   Third Generation F-Body Message Boards >
Tags
383, 98cr, cc, engine, headman, info, motor, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
