No start when hot
Car: 89 IROC-Z 5.7
Engine: 5.7 TPI
Transmission: A/T
No start when hot
Car will start when cold but if i take it for a drive and let it warm up and shut it off it most of the time wont start up till it cools back down
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No start when hot
Try an ignition control module. located under distributor cap under the rotor - about $45
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If it would stall when hot, then I would guess ignition module.
But I think the issue is restarting after turning the ignition off on purpose, in which case it's likely the starter.
theshackle
03-05-2017 06:37 PM
db057
08-11-2015 10:11 PM
