car hates me
car hates me
Ok i have read every post on here and other sites and im a almost broke and my 1991 3.1 V-6 RS is still not running here is what i have done replaced ECM, TPSx3, IAC, fuel pump, 6 fuel injectors distrubuter cap and rotor, ignition module, ignition coil, map sensor and timing chain an gears after all this i got it to run but it would not idol ran fine at high speed after 2 hours car shut down and nothing it turns over but wont start i pull plugs i get fire turn it over some more and remove plugs soaked with fuel i now have 4 sets of plugs i need help my mind is fried on this car at this point. oh and i havent poped a singal code since i replaced the tps which i believe was 35.
Linson
08-21-2015 02:12 PM
