Engine build in uk help !
Old 12-07-2011, 03:50 PM
CAMAROBEAV's Avatar
Hi I am trying to finish an engine build that i bought part finished.
It is as follows -
5.7 block no GM3870010 (010 020) 2 piece rear main seal
Edlebrock Performer 6089 RPM alloy heads
It is just a block with heads and an inlet manifold on.
I need help with the following -
No waterpump -
Do i need short or long? Does it matter?
Bottom pulley and damper
Noting there - how do I know which type to get?
Is there year breaks/sizes????
Alternator -
I want a modern small unit to keep the bay clean.
Are there any that fit and if so what brackets do I need?
i have none !
Power Steering Pump -
Are they all the same?
Again nothing at the moment so I need brackets as well.
I hope you guys can recomend some choices as I need to order asap to send to UK so i dont want to make any mistakes !
CamaroBeav
Old 12-07-2011, 03:56 PM
CAMAROBEAV's Avatar
Re: Engine build in uk help !
this is the engine and what its going in
Old 12-07-2011, 04:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by CAMAROBEAV
No waterpump -
Alternator -
You said it all there.
You need to decide what front drive system you are going to use because everything has to match up.
The distance from the block varies and that determines what pump and pulleys you need.
Balancers are all the same ( exp 400) so whatever size fits best 8" / 7"
Could try to find genuine 3rd Gen brackets , have choice of V belt or serpentine belt
or just run basic old skool setup ( prob cheaper ) using aftermarket brackets
Have a look at some local Hot Rods
Old 12-08-2011, 01:47 PM
CAMAROBEAV's Avatar
I want to run a serpentine belt with no a/c
Also i want it all in black ! No chrome !!!
So it looks more like a modern factory look.
I also need to get alternator, power steering pump and water pump as well !
Ive looked at Summit and Jegs and cant seem to find what I want.
Are there any other retailers over there that send to the uk???
Old 12-08-2011, 04:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Ive looked at Summit and Jegs and cant seem to find what I want.?
http://www.summitracing.com/parts/NAL-12497697/
Old 12-08-2011, 04:22 PM
CAMAROBEAV's Avatar
Perfect but about $800 shipped to me in the uk !!!!!
Old 12-08-2011, 05:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So start searching for a late 3rd Gen being parted out locally; get the drive brackets and pullies ,paint them,
then just buy the required parts to suit
Look around
Plenty of 3rd Gen specialists in UK
http://www.dbmotors.net/
have some 3rd Gens being parted
Old 12-10-2011, 02:09 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
You'll want an accessory kit off of a 350 from 85-88. However, some of them had reverse rotation water pumps. Your best bet, is to buy the kit from summit without AC. However, I'd recommend that you contact Robin at Auto Pontiac in London.
He'll be able to get you everything you need. Just tell him Matt who had the Qjet work done on the 84 T/A sent you. He'll know who I am. If you have any questions, PM me.
Terrell351
06-13-2021 01:13 PM
italiano67
12-11-2016 09:21 AM
sreZ28
08-14-2015 07:48 PM
bradleydeanuhl
08-12-2015 11:48 AM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: Engine build in uk help !
