Pics of HT383 cam drive end
Old 01-02-2012, 07:50 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Like the title says, does anyone have pics of the timing chain end of the GM HT383 cam #14097395. I have spent some time looking around on the net. I called summit. The guy at te counter wouldn't check or take one for me. Anything would be appreciated. I'm trying to find out if the cam has the big canter hole so the opti fits. I have a machinst that will bore it out, but I want to see if i can save some bucks.
Thanks a ton guys
Chris
Old 01-02-2012, 09:32 PM
ex-x-fire's Avatar
Re: Pics of HT383 cam drive end
This guy said this was an ht383 cam he installed.
Old 01-02-2012, 09:45 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Here is a picture of the stock camshaft that I took out of my HTE383 crate motor. It is the same as the HT383. It has never been used if anyone is interested.
Old 01-02-2012, 09:49 PM
rocko350's Avatar
yes it is. the water pump on an LT1 is driven off of a gear shaft pressed into the block above the cam, and it is drive off of the cam gear from the timing set. It doesnt look like it has the opti drive hole.
Thanks guys!
I have to come back over here more often.
Chris
Chris
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
1984HO
03-19-2021 11:59 AM
jharrison5
08-19-2015 05:53 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: Pics of HT383 cam drive end
