Casting numbers
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Casting numbers
Ok so I finally got to that crate 350 the head casting numbers are 3998983 or3998993 can't tell for sure and the block number is 10066036 what is everything
Received 1,664 Likes
Re: Casting numbers
Sounds like the "Hecho En Mexico" Goodwrench 350...
Like Apeiron said, trash heads, but a decent block core. Flat-tappet cam in it probably; most likely a 929. Pistons will be SUPER low-compression.
Good block casting core; but when rebuild time comes (or even, the "more power Scotty" bug) the rest goes into the dumpster.
Car: 1983 Z28
Engine: Forged 355
Re: Casting numbers
One piece seal means that it is fitted for a roller can I believe. That would be a nice upgrade, and it's a good block.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Casting numbers
It only means that it has a 1 piece RMS for certain. Those blocks have cast-in provisions for factory roller cams, and most of them have the machine work done to finish them, but not all of them have all of the necessary parts installed.
Engine: 383 Carb
Transmission: 4L60
Re: Casting numbers
You can put a roller cam in any block. It' just cheaper if you can use all the factory stuff.
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
09-27-2015 08:37 PM
