Engines started, high idle, then died.
Old 04-17-2012, 10:24 PM
MrBlah's Avatar
So, instead of trying to figure out engine tuning and wiring with my first true engine build with the engine in the car, I've got it all on a test stand. Now, I've done lots of searching and learning of crap. I haven't found the answer to my current problems.
First off, here are specs:
Holley Carb, manual choke, mechanical secondaries.
355 small block chevy, open headers
So, first time firing up, choke closed, it ran with a high idle. I didn't have a look at the tach at the time, but it reduced in rpm and then died shortly there after. This same sort of thing happened a couple times and when ever I got my hands to the butterfly valves on the carb to open up the throttle, or choke it dies instantly. Also, if I try to start it with manual choke open, it won't start. Now, I think it has to do with little things with the carb, but I'd like to know if anyone can help me pinpoint it here.
Old 04-18-2012, 05:27 PM
MrBlah's Avatar
Re: Engines started, high idle, then died.
anyone that has the power may close this thread. It works.
Frozer!!!
01-19-2024 04:55 PM
Spyder_TheGamer
12-25-2015 05:07 PM
Wade787b
09-29-2015 01:15 PM
bradleydeanuhl
08-12-2015 11:48 AM
killer777
08-08-2015 02:47 PM
Quick Reply: Engines started, high idle, then died.
