88 Camaro cranks but wont turn over.
Car: 1988 Chevy Camaro, sky blue
Engine: 2.8 V6
Hello everyone, I have an 88 Camaro that I just purchased on Friday the 4th 2012, yesterday I took it for a trip that was about 300 miles round trip. The car was running fine, when I got to my destination and would turn it on and off for things like pumping gas and going to the store things like that, the vehicle would not start it would crank but not turn over, so I let it sit for two hours came back and tried it again and the car did the same thing but this time I gave it gas and it turned on. So I decided to not turn it off after that and came home on my way home the car started to basically turn off and on while cruising on the highway at about 75MPH but it was so fast you couldn’t notice but I was driving at night so I could see the light blink and the needles on the cluster would jump once like if I turned it off and back on super fast. So I pulled in to a gas station and let it idle for 1 minute before I turned it off, then I pumped gas and put a quart of oil because it was low, got back in and did the same thing cranked and sound like its trying to start with that sound kind of like when you keep turning your key even though the car is already on but the engine would not turn over. I left it there and came back today in the morning and the car still did the same thing I kept trying and stepping on the gas pedal and finally turned on and parked it and haven’t tried it since any ideas why it wont turn over? Lights work fine all power works.
Everything is stock on car its a 5 Speed manual trany. 2.8
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
Re: 88 Camaro cranks but wont turn over.
Hard to say. Possibly starter wire is grounding out or a bad alternator.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
He says engine is cranking over fine which means
1. the starter and it's wiring are good
2.the alternator must be working correctly otherwise he would have a flat battery fast by his continuous cranking of the engine
Only need two things to fire a engine up;
reasonable to assume he has the 3rd component ;AIR
so he is either missing fuel or spark ( or possibly both )
Back to auto shop 101
Check for fuel and spark when engine is being cranked over and not starting
1 Post
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Not really shop 101.... i would check the wire connections at the starter, check the starter its self. If the starter cant crank the engine. Fast enough it wont start either, if you try to read what was posted sounds like a bad wire connection.
Car: 82 Z28
Transmission: T400
How would as he states "I gave it gas and it turned on" overcome your bad wiring problem
Car: 87 z28 stock
Engine: 305 tpi
i had the same issue with a chev 2.8 liter that was in an old AMC jeep. my issue was a broken tooth on the flywheel.
Bad guess
1 Post
Axle/Gears: na/2.73
So no one read what he wrote? He did state that when he goes to start it that it sounds like the engine is running when he goes to start it, so the starter is grinding, possibly loose, bad, bad flexplate, so which WOULD make it crank slowly and THEREFORE not start. Oh ya this was. Commonsense 101
Car: 82 Z28
Transmission: T400
You also get the same grinding noise if the engine is firing up partially (has fuel and spark but not in correct amount / time)
and driving flexplate against the engaged starter gear;
not because the starter is cranking engine over slowly
1 Post
Axle/Gears: na/2.73
Oh my god you are stupid, thats called a hard start its because of too much timing advance. If a starter doesnt fully engage the flexplate it will grind and crank the engine slowly because its skipping gears which will cause an engine not to start. Anything else you want to add and make yourself look worse off?
Car: 82 Z28
Transmission: T400
Seeing you are doing the calling out ;Junior
1.if you don't have the correct amount of fuel available, the engine will kick and try to fire up.
2.ditto spark ; if only some plugs are firing ( bad plugs or wires ) you will get same result
Big call from someone who has only been here a month and looking at your recent questions ; not exactly up to speed on Auto shop
(witness not having the cable connected on your trans)
You still haven't explained how by
"giving it gas "
he overcome your supposed bad starter wiring problem and the engine fired up ??????????
"giving it gas "
1 Post
Axle/Gears: na/2.73
Oh wow yep you got me im not a transmission guy, ill admit it. Thats why i dont help in the transmission section.
We arent talking about transmissions. Wrong fuel wont make an engine kickback. Its all about the spark. Ok one time pumping the gas got it to start, the other problem they have is a loss of power to the electrical sysem, therefore should start lookiin at battery connection starter connection, the starter could be loose from the block make it grind and by uck of the draw catch one good time to start engine.
Car: 1989 RS Drop-Top
Engine: 305 TBI
No flexplate.......flywheel, its a stick.... I think the whole problem is the nomenclature that is being used to describe actions. Start from beginning, I don't believe everyone is in the same book let alone the same page..
1 Post
Axle/Gears: na/2.73
Hell no where near the same book, i dont think same genre lol. Well i think we scared roque away :/
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
My alterior motive here is that I am patiently waiting for his advice in my own thread, and he's being tied up here lol. So that being said, later.
1 Post
Axle/Gears: na/2.73
The driver also states that while driving down the road the engine and gauges shuts off then comes back on, which states a bad electrical connection somewhere.
1 Post
Axle/Gears: na/2.73
Yet while driving down the road the lights will shut off then right back on and the cluster gauges reset, uh sounds like electrical issue ie bad connection, ya sitting still with a bad connection the lights can come on just fine but the starter may not work correctly. But hey i may be wrong it could be lack of fuel or spark causing the cluster gauges and headlights to loose power. Unfortunately we may never know.
86IROC112
08-17-2015 02:00 PM
db057
08-11-2015 10:11 PM
