Back to a no start. Just click
Car: 1986 t/a
Engine: Lg4 305 carb
Transmission: 700r4 auto
Axle/Gears: 2.73 posi
Hey starter problem again, so far ign switch, NSS, Batt cables, Batt, starter and solenoid. Car was starting great, running fine. Came out other day went to start. Got the (cha click) and won't start.
Turning key million times started once. Shut it off no more start!
Climbed under it with screwdriver jumped solenoid and starter spins..
Wires all new. Grounds all cleaned, tight.
Would it be bad solenoid??
Re: Back to a no start. Just click
If starter spins but does not come out to engage ring gear it is most likely the solenoid IMO
Car: 1986 t/a
I found the problem. Housing to the solenoid was cracked,
I might have over tightened (dumb*#%)
Anyways put another one on. I roll once again!!!
Those parts are made cheap to bad the prices are not the same good luck.
