Checking hood air cleaner clearance
Old 08-06-2012, 06:00 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey I recently replaced my aircleaner, and its fairly tall. It doesnt hit the hood, but it looks really close. Its one of those triangle, mesh ones that suck most of the air from the top. Im worried that the hood may be too close too it blocking air, and my poor lg4 cant afford to lose any more hp. How can I check how close it is?
Old 08-07-2012, 03:44 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Checking hood air cleaner clearance
Piece of wax paper and some play doh.
Old 08-07-2012, 03:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Worry more about what the "triangle of death" is going to do to your engine.
Old 08-07-2012, 03:59 PM
Car: White 84 z28
Engine: Chevy 350
What do you mean triangle of death? If you mean it doesnt get alot of air through, I was worried about that too. But it seems to pull like it normally does with it on.
Old 08-07-2012, 04:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At best the foam deteriorates when exposed to gasoline fumes (such as are found directly above a carburetor) and lets little chunks get sucked into the carb, although sometimes it's not chunks and the whole foam insert gets ingested at once. At worst it catches fire if the engine backfires.
Old 08-08-2012, 07:22 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
guess where all that went?
Old 08-08-2012, 09:58 PM
Car: White 84 z28
Engine: Chevy 350
Dang. Ill be taking mine off. Thanks for the pic
Old 08-08-2012, 10:02 PM
Car: White 84 z28
Engine: Chevy 350
What should I get instead of it? I bought that because I just put on a edelbrock 600 carb and my old style round one didnt fit. Bottom hit the linkage, top nearly hit hood.
Old 08-09-2012, 04:52 PM
jkerr422's Avatar
i had one of those filters on my ford truck with the edelbrock carb and it cause the carb to backfire with in turn caught the filter on fire. luckily got it off there in time and yanked the carb and cleaned it like a son of a gun. i found chunks of the foam clogging my jets.
definitly would recomend taking it off asap
Vintageracer
01-10-2020 05:33 PM
86IROC112
09-07-2015 01:37 PM
86IROC112
08-17-2015 02:00 PM
wruiz
08-13-2015 09:07 PM
92purpz28
08-11-2015 02:30 PM
Quick Reply: Checking hood air cleaner clearance
