305 to 400
Old 08-12-2012, 09:19 PM
t/aburgler's Avatar
Car: 85 trans am
Engine: 305 tpi
Transmission: 700r4... for now!
Axle/Gears: 9 bolt 3.42
305 to 400
hi everyone, i recently blew the head gasket on my 85 tuned port 305 trans am. naturally i went out and bought a 400 soon after, knowing my 305 will serve a much better purpus as a paperweight.
so heres my plan:
rebuild block
port 400 heads, tripple cut valve job
port lower intake for tpi
roller tip rockers
headers and "free flow" 3" exhaust
http://www.compperformancegroupstore...ode=CL12-366-4 <- this camshaft
leave stock 305 tune
now i have read on here that a 400 works well with a stock 305 tune, as long as the injectors are replaced from 19lb to 24 lb. but this was with a stock 400, since this will be slightly warmed over, should i use a 27 or 30 lb injector? oh, and i am also changing my transmission from the stock 700r4 to a world class t5. any suggestions or commentary welcome, just looking for good advice on this build.
thanks!
Old 08-12-2012, 09:50 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 305 to 400
Heck no dont use a stock tune
Old 08-12-2012, 10:14 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: 305 to 400
Exactly why would you invest that much time, effort and money and then not get it tuned?
Old 08-13-2012, 01:37 PM
t/aburgler's Avatar
Car: 85 trans am
Engine: 305 tpi
Re: 305 to 400
The reason for a stock tune would be that i have the 85 ecm, which would have to be spliced over to an 86 or newer to be tuned, then i need a tuner and a dyno so im looking at at least a thousand more dollars to do all that. Not easy with a minumum wage job. I just need it to work, and then later i can work on making it work better, once i have some cash to throw around. The car was my daily driver
Old 08-13-2012, 08:28 PM
Axle/Gears: 4.11
Re: 305 to 400
Calll Wongs performance (google it) bet it doesnt cost anywhere near that.
Youll smoke that new motor without a proper tune right off the bat.
He can get you pretty close without the dyno at least where youre safe.
angel2794
09-08-2015 06:22 PM
greenyone
09-02-2015 03:39 PM
IROCtometal
09-02-2015 02:01 PM
FLAP
Camaros Wanted
09-02-2015 09:22 AM
Quick Reply: 305 to 400
