89 formula 350 gas tank question
Old 08-20-2012, 11:50 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Hi folks
Been a while since I have worked only car. Getting ready to reinstall my gas tank. I took it out some time ago to install a new pump. There are four feed lines coming out of the sending unit. One is gas feed one is return and one is I believe for pressure. However I have a fourth line that had a plastic part that since broke, and was lost. My only guess is this was some sort of pressure relief valve but I can't find anything that states what it was and used for. Any ideas to what this was and where to get a replacement would be great. Thanks!
Old 08-21-2012, 12:49 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: 89 formula 350 gas tank question
I am not 100% sure if this will help.. But it think it might be for the Evap Canister
Old 08-21-2012, 09:11 AM
Engine: 5.7
Axle/Gears: Stock
89 formula 350 gas tank question-img_20120821_094908.jpgIBMTECH
Thanks for the quick reply. I have gone to 2 auto part stores, no luck. I have check the factory service manual which I have, the drawings show only 3 lines coming out of the sending unit. I am attaching 2 pics of what I am talking about. The pic shows the line having a white plastic piece coming out of it. What was on it broke off upon removal and I cannot find the part which I thought I preserved.
From the bottom up:
1. line with threaded nut is the main fuel line
2. 2nd line up from fuel line is the return I believe
3. 3rd line is for the pressure/vapor if correct
4. the top line with plastic piece is the mistory
Old 08-21-2012, 10:14 AM
Engine: 5.7
Axle/Gears: Stock
Nevermind I know what it is. The hard to get gas tank vent valve. WHY would they discontinue a part that it seems so many people need?? STUPID GM!
Infested
05-22-2018 11:56 PM
okfoz
03-09-2017 02:35 PM
Andrew6.688
12-13-2015 10:59 AM
mustangman65_79
09-01-2015 03:51 PM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: 89 formula 350 gas tank question
