V-belt to Serpentine setup
Car: 87 GTA
Axle/Gears: 3.42 posi
I was wondering of this swap is worth doing? My 87 TA is Tpi and obvious running old school v-belt. Can I use my alt and PS pump? I'm running an electric Wp. I was going to order UD pulleys and since their a lot easier to get for the serp set up I was thinking of jus swaping it over. Also what are the pros and cons of doing this? Thanks in advance. I tried searching for this if there is already a thread can someone link me to it.
Re: V-belt to Serpentine setup
You will have to get a different alternator, yours is the same model but the ear is cast in the wrong position on the front half. You can not reclock it to fit. the P.st. you can reuse but you will have to pull the pulley off and replace it w/ a flat belt pulley.
Easiest is to get a complete front drive system off a later car, incl. the pump and everything..it's a bolt on deal.
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Honestly I don't really understand why some people insist on this swap. Nothing wrong with V-Belts. Only advantage I could see is cleaning up the front of your engine a bit.
If you want to do it the best bet is a junkyard. Grab the alt/PS/crank pulley and swap them over.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
BG1959 (12-05-2019)
Car: 87 GTA
Would this affect my electric water pump? Also, i would have to swap to a serp system in order to run a super charger correct?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
An electric water pump shouldn't matter as long as the belt routing for direction is maintained on the rest of the accessories. I think we have members using March Serpentine Setup with electric water pumps, but I would think the OEM setup would work also.
Most superchargers are serpentine, so yes would be easier to swap if that was the case.
1 Post
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
no dont go serp! i made that mistake and regret it! i brok my alt bracket on my serp and it left me stranded 2 times now... mind you im using a set up from a truck, just get the underdriven v belts and its a 6 dollar fix if you blow the belt vs 40
I did it on my camaro and it was probably the best modification I ever made. Makes changing any accessory easier, runs quieter, looks nicer.
With the electric water pump you'll have to reroute the belt and I'm not sure how that will work but it's probably doable. You'll need all new accessories. Some guy used to sell kits for $3-400 about ten years ago out of florida, not sure if he is still around.
Car: 1982 Z28
Engine: 5.0L
Axle/Gears: Ten Bolt Disc Posi 3.23
I know this thread is old, but how in the world did you break a bracket? It must have been defective when you installed it, or your cracked it without noticing it. GM puts these brackets on 5.7 trucks, Suburbans, Jimmys, ect
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
GM added supports later on because the aluminium brackets failed over time. It's often not possible to use the supports with headers though.
The GM serp kit has provision for headers. Pics of the braces/spacers can be seen in posts #16 and 17 below:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
JamesC
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I'm seriously considering a serp belt system. Anytime I go over 6200 rpm I throw a belt off. Always the alt/water pump belt.
Neither. My car is a factory LG4 carb'd car. I was lucky enough to find that the passenger side head had the three holes for the serpentine bracket. No modifications needed except for minor wiring for the alternator and different hose for the AC.
Engine: 4++,350 & 305 CIs
I have heard of the dreaded broken bracket b4, most cases were because the bracket wasn't fully tightened down. (some had bolts that had bottomed out in the heads)
The early aluminum brackets had 3 metal braces per side. Then they went with 4 total later.
I removed all of my brackets years ago and have 240,000 miles on my car with original brackets on it.
Mine gets run up to 200mph and 8,000 rpm quite often. It also has 200,000miles on the SLP serp bet and underdrive I put on it in 1992 or so. (prolly should be changing that..) lol
Engine: V6, V8
JamesC
JamesC
I'm guessing that kit is based on the TPI set up?
TBI and TPI use the same brackets.
If you have different ones, they are from a vet or truck.
Since moving to Texas, I have been wanting to come up with a better A/C setup to replace the non working stuff on my car. I have never even charged an A/C system from a total start up (but have added charge), so it will be a learning experience. I have been accumulating tools such as a vacuum pump, hose crimper to make my own hoses, fittings, pressure switches, can valves and etc, and have been hanging out at a local shop trying to get learned up about it a little more.
Despite my lack of experience, I want to make some changes. If it doesn't work out I'll have to fall back to professionals, but I'm game to give my ideas, and learning curve, a try.
I've been rounding up some 1990 vintage Camaro/Firebird FOE aluminum brackets, bolts, brace bars and etc. I have seen the high price GM Serpentine Conversion Kit, but yikes! That is pricey! And, several people, pros and otherwise, have told me that the GM Barrel compressor is definately not the hot setup. And that is being kind. There is a company in South Fort Worth called Old Aire, that has a bracket to put a Sanden compressor in where the GM compressor goes in the Passenger Side FOE bracket. This gives you a better compressor with a divorced oil sump, and puts it on the Passenger Side so that you will not have the big A/C hoses crossing over the engine to the Driver's Side like I do now. I'm also going to move my drier/separator to the radiator support to clean up the engine bay and give better access to the right rear side of the engine. I will mock all of this up on an engine on a stand while out of the car. I may try putting water pump spacers in and space the FOE brackets out as well in order to be able to pull the RH valve cover without having to remove the compressor first. And, my old, tired 305 does not have the correct bolt holes in the passenger side head, but there is a new engine and heads in the works (a long way off!).
I've also got a bigger radiator and will probably go to an electric cooling fan set up.
Another thing I want to try is the Ford "white" plastic nozzle. It supposedly makes better cooling at lower speeds.
I will undoubtedly have to do some cutting, moving and fabrication to make this all work. It should be interesting! Now if I can just find the time to get after it, building the new engine and all.
Car: 1982 Z28
Engine: 5.0L
Go with a serp setup, you won't regret it. I did mine and it takes five minutes to pull the WP, Or five to do the ALT. Plus you can upgrade your AC to R134 too. Provides a cleaner look. Get the brackets off a 93-95 truck or Suburban. Or a 90-92 V8 Camaro. Search Car Craft serpentine on the web they have a great article with lots of pictures, advice, and part numbers. Anyone who stays with a V-belt is delusional.
Im trying to look for a correct wiring diagram for my conversion. I have the large Alternator (86 IROC) and Im converting to a serp setup. I got the small alternator but Im confused about doing the 86 style passengerside wiring to the driverside small alt wiring.
Car: 1982 Z28
Engine: 5.0L
What do you mean correct wiring? The heavy red wire goes to the alternator battery post. You can buy an adapter for the field wiring from Powermaster. You need the two wire adapter if you have the ALT light in the dash. What else is there?
Red to S pin, brown to L pin.
I bought a universal CS alt pigtail from my local parts store (likely Dorman) and the brown wire connects to the blue wire on my pigtail (field flash/battery lamp), red to red (remote sense), and the black wire on the replacement pigtail was not used.
GD
GD
GD
GD
#42
Bolt up the bracket, transfer punch the hole, remove the bracket, drill and tap. Use sealant on the bolt.
If you have never done something like this I would suggest seeking professional guidance. Drilling and tapping a horizontal hole into your cylinder head that's backed up by a coolant jacket while the engine is installed in a vehicle is probably not the way to start learning to drill and tap holes.
GD
GD
