I need some help with wiring. I have a diagram
1 Post
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Alright i have a 1987 350 tpi motor swaped into my 89 s10, and its all the same wiring still but i had an issue with the injectors not firing and long story short the pinouts b1,c16 from the ecm were not getting power so i wired them up to my battery with a fuse and it ran great all day yesterday, then it died after about 2hrs of on-off driving and it started popping the fuse i had so i cut the 2 orange wires from ecm which were b1, c16 and i had them only connected to power and it still wont start, so i found they go to the burn off relay whatever that is and i connected a new wire to there from the ecm and cut the old 2 wires, and it still wont start. Ill post a picture of the wiring diagram so you can see if the 2 wires need to be hooked up anywhere else now aswell, thanx and sorry for the story lol
Here is diagram link that shows pinouts from ecm
http://chevythunder.com/1986-89_tpi_ecm_schematic.gif
Re: I need some help with wiring. I have a diagram
is the fuel pump running? the splice pack that feeds b1/c16 also feeds the fuel pump relay. follow the schematic. everything that is fed off that splice needs to have power at the same time.
1 Post
Car: 91 Z28 camaro
Ya its getting fuel and i can hear it and it has 45psi pressure, so what else would the wire effect, because i cant figure it out on the schematic
