Ali heads 10088113 on a 305, what cam spec?where can I get valves/ springs?
Ali heads 10088113 fit a 1990 TBI 305 Camaro?
If so is there much of a power gain?
Thanks, Carl.
Thanks, Carl.
Received 1,664 Likes
Re: Ali heads 10088113 fit a 1990 TBI 305 Camaro
Almost...
They use perimeter-bolt valve covers, they have the pre-97 intake bolt pattern (angles), and no EGR.
SUBSTANTIAL power gain; considering that the 187 heads are about the worst there could possibly be. ANNYTHING (almost) is an improvement.
My 305 doesn't have egr on now anyway, so that's fine.
What manifold would I need to keep running tbi?
And different valve covers isn't a biggy
Found this manifold, but can't find a converter?
http://m.summitracing.com/parts/edl-7101
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://www.summitracing.com/search/p...=TBI%20adapter
seeing you are not concerned about EGR ,you could always use your stock TBI intake and just slot the 4 center holes to suit the older style bolt angle like is done on the aftermarket intakes that fit both bolt angles
1 Post
Car: 1985 Trans Am
Engine: 1990 Corvette L98 w/ ported 081s
Transmission: Stock Non-WC T5
Axle/Gears: 9 bolt w/ discs
As long as you upgrade the springs.
Just be mindful that anything above around .525" of lift will require you to cut down the valve guides for clearance.
Found a set of brand new but complete bare 113 ally heads for sale, can get a set of 1.5ratio roller rockers.
Now I know I wants the standard valves (1.9 inlet, 1.5 exh). But so I want standard length? What valve springs strength should I go for? And what would be the best cam for fast road/ track?
Any help appreciated!
Thanks, Carl.
Thanks, Carl.
350 isn't an option at the moment.
Vortec heads would be, but getting them cheap and to work with TBI in the uk isn't such an easy option.
Also I'm fairly confident that I can get what I want out f a 305 with out swapping engines.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Ali heads 10088113 on a 305, what cam spec?where can I get valves/ springs?
I thought Ali might have been a custom head porter or something.
1 Post
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
At first i thought it might have been AI just miss spelt but the " Yo mamma " comment made the light come on...
1 Post
LSX FTW!!!
It was a joke folks, no need for you all to get your panties in a twist (again that's a joke). Although I now know how to get my topic abit more noticed?
So anybody able to direct me in the right direct with cam/valve springs needed?
Ones that would work with my heads and roller rockers if possible?
Car: 1971 Camaro
Engine: 427
Google "gm hot cam kit"
or search it on jegs or summits site.
Ahh so this one?
http://www.jegs.com/webapp/wcs/store...=&pgGrp=search
