top mount supercharger install on a stock 2.8L. Good idea?
Old 07-31-2013, 02:54 AM
CamaroPaul's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6 Multi-Port Fuel Injection
Transmission: 700R4 / 4 Speed Automatic
My friend gave me a great condition top mount style supercharger from a GM V8 motor and I'm trying to figure out if it will work on my 2.8L. All I have is the supercharger itself so I need some expertise in what I will need to make this work. If it will work. I will post some pics of the supercharger tomorrow so accurate help can be given. Thanks.
Old 07-31-2013, 09:13 AM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Re: top mount supercharger install on a stock 2.8L. Good idea?
It's going to take a ton of cash to do right - You'll need to cast and machine a supercharger intake manifold that will bolt up to the 2.8L V6's heads and bolt up to the supercharger's base. Also it has to align the pulleys to where the supercharger can be driven off the crank.
I've seen odd combos and if you're good at welding aluminum then sometimes you can take a stock aluminum manifold and cut it and fab up a way to attach a supercharger baseplate to it. Those are more for "looks" rather than performance.
Remember the 2.8L has a reputation for cracking heads and blowing headgaskets stock - add boost to that and you're going to be replacing heads and headgaskets often.
As they say - is the juice worth the squeeze?
My recommendation - sell the supercharger to someone for cash and pick up a 350/700R4 combo and put it in place of the 2.8 - heck if the supercharger is complete and in good shape someone might even trade straight up for it...
Old 07-31-2013, 04:10 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Why not? Go for it, I'd blow up small engines for fun. Worse that could happen is that you might have to replace that 2.8 with a 350.
Old 08-22-2015, 09:34 PM
firebird2.8's Avatar
u can go an buy3/16 alumonm and a figer out where u wont it to set u can sort it to gether to make the intake i have made the intake and a blower machine work not really need but need to port heads and biger injecterz
Old 08-23-2015, 03:12 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i've seen pics on teh internets of people that have mounted one of those 3800 superchargers on fwd 3.1 engines by just cutting a hole in the top of the plenum and bolting it there... i don't know how well it worked, but it sure looked impressive..
Old 08-23-2015, 09:11 AM
Re: top mount supercharger install on a stosureck 2.8L. Good idea?
Originally Posted by novaderrik
i've seen pics on teh internets of people that have mounted one of those 3800 superchargers on fwd 3.1 engines by just cutting a hole in the top of the plenum and bolting it there... i don't know how well it worked, but it sure lookv ed impressive..
sure but if performance no the supetcharger is to high it is takeing the air to long to get to the engine but if u wont it for looks yes
Old 10-23-2015, 01:42 PM
do you know where i can buy a conversion kit to change a auto to a manual
Old 10-23-2015, 01:54 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Hawksthirdgen
Plenty of threads on this too
Old 10-23-2015, 02:06 PM
where
Old 10-23-2015, 03:10 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
http://www.rs25.com/forums/f7/t10681...otsa-pics.html
Something like this might work.
Frozer!!!
01-19-2024 04:55 PM
customblackbird
08-15-2021 10:16 PM
jaridjohn
04-25-2019 03:21 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
dhonda200
08-11-2015 11:50 PM
Quick Reply: top mount supercharger install on a stock 2.8L. Good idea?
