Thirdgen Tech "How To" Videos
#101
Car: 91 Camaro RS 305TBI
Transmission: 7004
Axle/Gears: stock posi .373
Re: Thirdgen Tech "How To" Videos
i have to replace my driver side door pin... my door isn't shutting right.. i'll get to that right after i fix my gauge cluster, and my hatch popper just stopped working today too... vid for any helpful door tips would be awesome
#103
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
door pin ill keep in mind ... troubleshooting the trunk motor sounds like a vid i can do soon...
to get more clearance for the engine pan..you can rig a bar up on the strut mounts..OTC makes an engine holder where they do exactly that..take the mounts off, jack up the engine..and hold it in place with the strut tower bar...It will be tough to put a video together for this one..but i'll try
#105
^how to install headers / header gaskets on a thirdgen..
#108
I also do regular cars....
#111
^ Can be applied to thirdgens ( How To Bleed Your Brakes Procedure )
#114
Can use an offset wrench on the bleeder for the drums..ground effects i need to take a look when i get ome
#115
Engine: V8 305 TBI
I've been watching some vids lately and I don't know if you have already made one but if not can toy do one on how to remove the ground effects under the door I don't want to experiment and break mine lol and thanks nice channel by the way
#117
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You can use a socket if need be to loosen it and then an open end wrench to open/close it as needed to bleed. Be careful though not to round it over.
I have something similar to this and it comes in handy for bleeding and also works for some batteries too. Kind of a go to tool that I keep handy. (IIRC, I spent less than $10 for mine.)
#118
I would love to see how to replace the valve seals on a TPI engine.. end to end with heads on.
#119
Thanks guys! Been very busy with customer cars lately..and yes ive been taking videos of those too .. I have a few thirdgen electrical how - to videos in line also..ive been getting a ton of requests..so my apologies if i dont get to urs..thanks for watching !!
#120
We all thank you for doing this! great idea to video your work and helping us!
#123
Thank u guys..dont forget to subscribe
I had a customers car here the other day and he had no heat..it was a thirdgen..i threw the below video together as a quicktip in troubleshooting a no heat condition...
#124
Car: 1989 & 1990 RS V8 TBI
Engine: 305 5.0 L
Car: 83Z28 HO
Transmission: G Force 5 speed
Great vids!
-How about the dreaded "How to repair your lose tilt steering column"….common Thirdgen issue. Not too bad, but not fun either...
#126
Engine: 305 5.0 L
yeah I have a simmilar problem, but mine isnt loose on the tilt, but has lots of extra play when turning i would like to get rid of that play so my serring wheel is tight and as soon as i turn the wheel my tires turn I hate having a 4inch tire delay
#128
Engine: 305 5.0 L
Engine: 305 5.0 L
Awesome bro thanks!!!
#131
Engine: 305 5.0 L
^ What he said lol
I actually have a loose steering column on my Camaro and I have a good column. I will change the collar from the good one over to the bad one..i will explain it all in detail..
Don't forget to subscribe!
tons more thirdgen videos to come!!
#134
Video s updated!
#135
I also have a video on how to replace the heater blower motor..by request
#137
Bump..working on more videos..stay tuned
#138
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
nice videos !
#140
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Oh Crap I didn't know this was common my car has the lose steering tilt adjustment too!!!! I figured it was just a loose bolt some where in the column. What is it and how hard to fix? Any video on this yet?
#141
There is a collar inside the steering column that wears out...
Here is how to install super bright Oracle LED headlights on a thirdgen...
#143
^ its on the "to do" list...
Here is a quickfix on those pesky thirdgen vents that keep moving around...
#145
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
so I have to ask...is there monetary compensation you are receiving for these?
I have been seeing your videos pop up on my local craigslist, and I'm pretty sure you don't live near me
#146
1 Post
Car: 1992 B4C 1LE
Engine: 305 LB9
Transmission: 5 speed
Can you do a vid showing vacuum line replacement on the 350 tpi? I cant figure out where the other ends go. previous owner removed them and put rubber caps on.
#147
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Oracle LED Headlight Installation - How To Wire - YouTube
#148
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
How to read and understand automotive Electrical wiring diagram schematics
