Thirdgen Tech "How To" Videos
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Hi Guys,
Some of you might have seen me around the forum every now and then. Earlier this year I started making "Tech How To" videos on YouTube under the name KLOWNY1969. The majority of my channel is related to thirdgens and my videos range from the begining level mechanic to high performance and electrical. I also work on regular cars for my customers and tape those jobs..
I figured I'd get some videos under my belt first and then formally come out on TGO. So far I have over 145 videos and 300,000 views on my channel.I attached my auto relay video below which is one of my most viewed videos for you guys to see..
I also include a few videos of my 1991 camaro rs 383 stroker!!
If you guys have any requests for any future video please let me know, and I will try to accomodate you guys.
You can also subscribe to my channel for free to be notified whenever I post a new video.
Thanks,
KLOWN
Thanks,
KLOWN
Re: Thirdgen Tech "How To" Videos
Any Vid requests?
Car: 1991 RS
Engine: L69?
Awesome channel, was just checking it out. You just helped me solve about 4 different problems much easier than I would have done it I didn't check every vid yet, so if it's up already I apologize, but would you be able to do a fuel filter replacement or diag vid at some point? Someone dumped sugar in my tank about a month ago and I believe it's finally starting to become clogged, a video would be a HUGE help for me to replace it if at all possible.
hmmm I have a custom steel braided setup on my camaro so it wont be that helpful..but I think i can come up with something..Thanks for watching and dont forget to subscribe for free
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Can you put up a link for subscribing? I'd like to see some more of these.
Thanks!
Thanks!
http://www.youtube.com/user/klowny1969/videos
Hey guys..try the above link and you can press the subscribe button..thanks for watching ..more thirdgen vids on the way
^The above vid was something i threw together real quick the other day..
^ fuel filter replacement..as requested
One thing to note about the fuel filter is that once you tighten everything down you should pressurize the car by turning the ign key to run and check for leaks..
and the bolt is a 10mm bolt that holds the bracket to the body..but its not necessary to take off
any other requests?
I did a series of Carburetor videos that some of you might be interested in..including a holley main body swap which I included below...dont forget to subscribe for free
You got it man..thanks for subscribing..below is a vid on how to replace a window motor..the car is a 91 GTA...enjoy..
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
was wondering if you could do a video of this method from chevy thunder seems a lot of people have this code myself included and not 100% sure i am correctly checking the o2 thanks
http://api.viglink.com/api/click?for...38193882031910
I dont have a car that has an o2 sensor hooked up currently..You can take ur o2 sensor off and test it with a torch and a mulitmeter if u want..there are tons of vids on youtube on how to do that..
you can also ohm test the sensor cold to see what the resistance is..i have a video on doing that...
no prob...any other requests?
I might do a gas tank / fuel pump replacement video this weekend
1 Post
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Wow so many useful vids how did i not see those on youtube before. Good work. Should do a t5 rebuild vid haha. Idk if i have a request yet, current problem is my speedo gauge isnt working for what ever reason
Thanks Guys!
I will be making a thourough step by step video on how to take a thirdgen gas tank out and swap out your fuel pump..
for the speedo gauge..i would first check to see if ur getting signal to the gauge..
^not a problem
^hmm i have to take a look but i think i have a few spare seat belt assemblies laying around..
Hello Manolis,
Great info.
How about installing a 4309 Mallory fpr from square one, to be able replace a TBI with a carb on your typical L03?
Recommended fittings and such?
Great info.
Also , if your looking for third gen specific PIA repairs , how about a vid of changing the frame mounted portion of our engine mounts . The first one I did (my 87 TA) I ended up taking out the springs to get at the hardware hidden in the frame , but by my second one (my 89 Firebird) I had gotten the crazy idea to reach in between the spring and frame and using a stick welder I put a little tack weld on each of the three nuts to hold them to the frame so the bolts would come out . No big welds , just a couple of light tack welds on each that could be broken off in the future should the need ever arise . I shot a little bit of paint in there when I was done to prevent rust and did the job in a couple of hours instead of a couple of days (like the first one I did) .
Thanks guys..those mounts are a pain..love the tack weld idea..i have alot going on but i will get to these vids..thanks again
^yeah an air gun with a rubber tip..didnt get to do any vids this past weekend..too many things going on..will get to it soon hopefully
A little misinformed on the wiring of a relay. pin 30 is the supply side(battery) pin 87 is the load side(device being powered) pin 87a is the alternate load( say, switching from high to low beam circuit). It will obviously work the way you have it, but it is not designed to be that way.
Here is a customers thirdgen i had the other day ... Did a full steering assembly overhaul..
Subscribe!
Subscribe!
Thnx got alot more thirdgen vids in the works!
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
How about a video removing a stock starter...that should be fun. I unbolted mine but I can't get it out from behind the y-pipe. I actually got it stuck under the control arm, and sadly I have to take apart the passenger side shock and spring to get it out. I was going to try removing the exhaust, but the bolts on the y-pipe collector are corroded and would likely snap.
Thanks!
Thanks!
Thanks!
Thanks!
#42
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Thanks!
Thanks!
the trick is to replace it with either a t5 starter or a mini starter(id choose this one) so it fits a little easier
#43
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
subscribing to this thread, and also to your youtube channel soon thanks for all this tech info dude!
#44
Car: 88 GTA Notchback
Axle/Gears: don't know
#45
I couldn't get it out, it actually got stuck in between the control arm and exhaust pipe. I unbolted the y-pipe, unfortunately one stud snapped (which can always be expected when messing with exhaust).
I already bought a starter from a part car, got it for only $25, whereas mini starters cost more than $100. I may seem cheap but I on a college budget, and only work one day a week. Plus I spent most of my savings on the interior.
#46
Thanks guys
Hahahaaa the stock setup for starter replacement is a bitch,! To be honest..all the thirdgens i worked on so far have either aftermarket y-pipe or smaller starter..but i will definately make a vid on a stock type of starter rplacement when i can..
Below are two vids..one on how to change a front strut..and the second is how to replace a strut mount..i also show examples of a bad strut and mount and how to diagnose!
Dont forget to subscribe to my thirdgen channel
Thanks to all!!
Thanks to all!!
#48
Thank u
#50
^ rear lowering springs and shocks
