new intake manifold gaskets problem?
Old 04-24-2014, 03:57 PM
up_dn_man's Avatar
I have a 89 camaro rs v6. I just replaced the intake manifold and plenium gaskets. I also replaced the stock injectors with ones from southbay. I adjusted the rocker arms so that the pushrods were tight. I started the car and it sounds kind of like a harly davison motorcycle. And it wants to stall if you are not hitting the gas. Could it be that the rocker arms are to tight. Thanks
Old 04-24-2014, 06:08 PM
ex-x-fire's Avatar
Re: new intake manifold gaskets problem?
Yes, you have to adjust the rockers when the lifter is on the base circle of the cam.
ASE doc
Alternative Port EFI Intakes
01-12-2020 11:35 AM
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
theurge
08-21-2015 12:46 PM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: new intake manifold gaskets problem?
