Help- Square relay to Oval wiring
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Help- Square relay to Oval wiring
No, I wouldn't trust the A:A, B:B method. Match up the wires for what they do. Do you have the old relay? Sometimes relays have a diagram printed on them, I would trust that or a wiring diagram. As a last resort, you could follow the wires on the car to see where they go and what they do, and also take the cap off the relay to see what the solenoid is doing.
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
It has to be easier ?
color to color wont work so i will look at the old relay..
Glowsock
01-09-2017 04:06 PM
