Camaro 85 Iroc sensor
Hi I have a camaro 85 iroc TPI
305 and i was looking on the engine right side(passanger side under the head by the starter has a sensor witch I took off Bc was broken and antifreeze came out the sensor is fat wich looking around says is a knock sensor? And on front of the engine under the MAF has 2 more sensors one it has a square plug pigtail and the other one round can some tell me what those sensors are thank you
Received 1,672 Likes
Re: Camaro 85 Iroc sensor
Thing between #6 & #8 spark plugs = fan switch
Thing at very bottom of block about 1" above oil pan between #4 & #6 water jackets (by front end of starter) = knock sensor
Coolant could come out of either one
The other 2, the one w yel & blk wires is the coolant temp sensor, not sure what other one you're asking about
Linson
08-21-2015 02:12 PM
mustangman65_79
08-11-2015 03:17 PM
