won't get going
won't get going
I Have A 85 Z28 With The 305 Carb And When Im Cruising An Boot It Down To Pass Someone I Can Hear The Secondaries Open And The Motor Revs But The Car Doesn't Feel Like It Kicks Down Or Takes Off Like It Should If I Let Off the Gas A lLittle Bit It Seems To Drop Down And Take Off, I Tired Adjusting The TV Cable But No Difference Moving Adjuster One Click Either Way, The Carb Was Rebuilt By Myself But May Not Have Put Something Back Together Right Possibly. It Seens.To Go Good From 0-60. I Have Also Notices That It Drops Into Reverse And Overdrive Kinda Hard When Shifting Between Gears But Shifts Smooth When Driving. Any Input Would Be Great Since Its A Little Frustrating
the_hamturdler
09-30-2015 12:50 PM
