No Power to Distributor
Old 11-23-2014, 02:43 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
I recently purchased a 1986 trans am with an LG4 and T5. The car hasn't ran in at least three years. My problem is that I dont have any power to the Bat terminal on the distributor. At first I thought the ignition switch was the problem but then I did some searching on here and it seems like when an ignition switch is bad the car wont crank. It doesnt seem like anything in the interior works either. I have no radio,gauges,turn signals, but I have power windows still. Any help is appreciated.
Old 11-23-2014, 04:18 PM
mlbinseattle's Avatar
Car: '84 Camaro Z28
Engine: 305 HO
Re: No Power to Distributor
Ensure all contacts on the ignition switch and dizzy cap BAT terminal are clean. After sitting up for years, it's possible the connections have become somewhat corroded. It may not look like corrosion, but it's enough to make for a bad connection. As far as everything else, pull all the fuses and clean the contacts and fuse holder contacts real good.
Old 11-24-2014, 04:16 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
Ignition switch was the problem. There was almost no corrosion on the terminals. I mistakenly took the switch apart and saw a ton of corrosion. I put a new switch in and the lg4 lives again!
Old 11-24-2014, 04:27 PM
Car: '84 Camaro Z28
Engine: 305 HO
Mine sat up for 12 years. I had to drop the fusebox and give it a good cleaning. Nothing looked like the regular, green or white looking corrosion, but all the contacts were "dirty". Cleaned everything and it was all okay, afterwards. Happens to bulbs and sockets, too.
Glad to hear all is well, now.
1992 Trans Am
05-10-2023 07:19 PM
Caspar
06-19-2016 11:19 PM
sailtexas186548
08-24-2015 10:11 PM
stalkier
08-21-2015 01:54 AM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: No Power to Distributor
