High idle/stall with acceleration
Old 11-23-2014, 10:39 PM
thejman92's Avatar
Hey everyone, I'm hoping to get a little help.
I picked up an 87 trans am with a 305 LG4 Rochester CCC Q-Jet in April and still haven't got it running reliably yet. It had more or less been sitting since 95 when I got it.
I'm having two continuous problems. It idles high all the time, and it wants to die when I give it gas (in gear).
In an attemp to eliminate gas and vacuum related issues here's what I've done so far: inspected vacuum lines, replaced the three vacuum diaphragm purge valves, ripped out the intake manifold and replaced the gaskets, sent the carb away to be profesionally rebuilt and adjusted, replaced the alternator (it powers the electronic choke), replaced the mechanical fuel pump and filter, and checked the fuel line going to and from the pump and vapor canister. Oh and also through on a new cap and rotor for the distributor.
Any thoughts on what it could be? Ignition? Computer? Bad wiring? One of the previous owners had an after market security and sound system installed. And the other attempted to remove the security system with only about 50% success. Keep in mind also, who knows if mice could have chewed something.
Thanks!
db057
01-10-2020 08:55 PM
Racerx974
09-19-2015 10:16 AM
amcnellis
09-16-2015 04:16 PM
ULTM8Z
09-16-2015 09:15 AM
Stroopwafel
09-11-2015 06:38 AM
Quick Reply: High idle/stall with acceleration
