To de-screen or not to de-screen a MAF
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
I'm sure there's been many threads on this whether to de-screen or not to de-screen a MAF, but would appreciate getting new comments on this.
Thanks in advance.
Thanks in advance.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: To de-screen or not to de-screen a MAF
^Agreed^ Don't do it.
I've tried it on several vehicles, but in most cases caused issues like Tuned mentioned with no gains. And those "issues" are not consistent, thus difficult or impossible to tune around.
It depends on why you want to de-screen it. If your engine needs more air then you need a bigger diameter MAF. It is unlikely that removing the screen will increase the air flow that much if your engine is starving. The restriction in air flow, if there is one, is more likely to be in the filter system in front of the MAF.
-a stock MAF flows 529 cfm @ 28"
-a MAF with no screens flows 711 cfm @ 28"
https://www.thirdgen.org/forums/tpi/...including.html
BumpaD82
02-26-2016 02:57 PM
