skipping, surging, sporatic idle
1 Post
Car: 88 gta
So now I have this peculiar issue...
I have a skipping no power issue... So here is all that I've noticed:
-Startup with intermittent skip..
-after running for a few minutes skip always happens.
-So bad that the idle fluctuates and sounds like its cammed..but with a very noticable skip.
-even with acceleration the engine lags, has no power, skips profusely...
-However all of sudden, if I can manage to get the tach above 3k, all power comes back with a fury, no skip and ***** to the wall accel.
So using an old school method;
I pulled the plug wires off the cap, while the engine was running...6 wires gave NO change in skip, 1 wire made it worse, and 2 wires shocked me.
So what is there to check next? And what else might I be overlooking?
Engine codes pulled were 13, 22, 45. However this codes could be as much a 1 1/2yr old. So I don't know what one is most recent.
Car: 88GTA
Engine: 5.7TPI
Re: skipping, surging, sporatic idle
I personally would put on a new cap, rotor,and wires. Throw some plugs at it too.
Ya might be surprised!!!!
Then disconnect battery and erase the codes and go from there
1 Post
Car: 88 gta
Plugs wires cap and rotor were replaced about 5k ago. Just a routine I follow with every car I own.
Erasing codes is defiantely something I gotta do.
1 Post
Car: 88 gta
I redid the 02 sensor and wiring..It looked like it was shorting out.
I erased the codes and codes 22/45 came back.
I rechecked the TPS its still set at .56 and no dead spots...
So now I "***"ume I should check for vac leaks?
I say assume as both indicate the possibility of a bad computer?
I also have an exhaust leak at the manifold, so I assume this can alter things also?
