Oil and Filter switch maybe?
Goodwrench 350 Crate Motor
Lunati 204/214 420/442 (448/472 @ 1.6) Hydraulic Cam/Lifters
Edelbrock Double Roller Chain
Comp Cams 1.6 Roller Tip Rockers
Crane Chrome Moly Push Rods
Melling HV55 Oil Pump
World Products S/R Torquer Heads 2.02/1.60 170 cc runners
Modified q-jet
Accell Billetech 60109 Distributor
MSD 6A and 8.8 Wires
Edelbrock Victor Water Pump
Edelbrock Tubular Exhaust
Hi-Flo Cat
Dynomax Cat Back
Hypertech Low Temp Fan Switch
Hypertech Thermomaster Chip
160 Thermostat
So I am currently Running 10w-30 pennzoil and ACDELCO Oversized Filter.
Car seems too run a little funny and has lifter tick on start up, didn't do it till i switched brands.
Wondering if I should use something like rotella T, or sythentic royal purple or something.
Car seems too have a miniscule Rear main seal leak, kinda worried about switching too sythentic because of that.
Any Ideas guys, and just straight forward answers please.
Modified q-jet
Hi-Flo Cat
Dynomax Cat Back
160 Thermostat
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Oil and Filter switch maybe?
Put synthetic in the engine. If you have seals leaking, repair the leaks.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have been running synthetic Mobil 1 Extended Performance 5w-30 oil with there Extended Performance "long" filter for over 9 years on an engine with 109,166 miles now. Strange thing is that when I bought the car it had the famous smoke on startup for the first 6 months and then disappeared.
Car: 1988 Camaro
I only use wix filters and on most of my cars I use synthetic Mobil 1 10W30 or 10W40 oil and if engine has a flat tappet cam I dump in a half bottle of lucas TB zinc plus or Break-In Oil AdditiveW/ Zinc with every oil change.
Which over sized filter are you running? I'd blame the filter before I'd blame the oil.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
im a firm believer in "wix" filters. I also use conventional "Castrol GTX" oil. I find any engine with more than 100,000 miles should be run on 10-40 in the winter and 20-50 in the summer. this makes for a happy engine. I never use 5w30 in anything worth keeping
i've been using valvoline vr-1 oil for many years. it still has the added ZDDP for hyd cam/lifters. no problems here.
i run an a/c delco filter with no issues, but i have heard many times that wix is top of the line.
Engine: TBI,5.0
I live in wine country and we get some rain in the winter but most of the year its absolutely beautiful . Not to hot or cold so I drive my car all year long. It runs clean and does not burn oil, but if you think I could be hurting the car I'm always willing to learn so what's up with the oil I'm running ?
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
How many miles are on the motor? (Talking to OP, not to you Ron)
Engine: 4++,350 & 305 CIs
Ditch the Delco filters. I lost 2 motors a few yrs ago b4 I figured out they had changed the guts of them.
Wix, napa gold and a few others are still good.
NO MORE AC DELCO, they went to elcheapo guts.
Car: 86 IROC
Engine: 5.0 TPI
5W-30 is what Mobil 1 recommended so that's what's in there.
Engine: TBI,5.0
OK, when I bought my car it had 87,000 miles on it. In the last 9 years I have only put 22,000 on it. The speedo rolled over and its setting at 9,000 (actual 109,000 miles)
My car was a wreck but the engine and wiring were unmolested so I must have gotten lucky because the first thing I did was change all the fluids and filters. Like I said,it smoked on startup but that went away after about 6 month of running the Mobil 1 EP Synthetic. I've really only started to work on cars and this is the only one.
I don't have the experience of some of you and can only speak as to what mines been like.
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
Navy8125
08-21-2015 09:32 AM
92camaroJoe
08-13-2015 06:07 AM
