high mpg & cracked water pump
Car: 86 Trans Am
Engine: 305 LB9
Hey guys, simple questions I hope.
Went home this weekend and did an oil change to 10w40, and found my coolant leak which is a cracked wp. I also topped off my tires. I also removed my hood insulation. Drove on the highway back to where I live and managed 31 mpg? I'm pretty sure they're only rated to 23 on the highway. Should I be concerned? It doesn't run rough or act sluggish at all..
Also the cracked wp (which was replaced a few months ago) and specific reason for this? I'm buying a good one online instead of the Pep Boys one but its really concerning
Thanks!
Thanks!
1 Post
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: high mpg & cracked water pump
Where did you get 23? I've seen factory window stickers for these cars showing 25 MPG for the 5.7L with the 3.23:1 axle. With your 305 and 2.73s, I assume, those will give you more. Plus how slow were you going? Drafting behind bigger vehicles? Tailwind? The '98-'02 Z28s were reported to do 30+ MPG, with another 41 cubes, but about 200 RPM less at cruise.
The math says 31 is a realistic possibility for your car.
Engine: 4++,350 & 305 CIs
A friend of mine consistently got 30-32 mpg on a long trips in his stock 91 TA vert with a 305 TPI, auto and 2.73 gear
Car: 86 Trans Am
Engine: 305 LB9
Oh okay. I got 23 from the epa website as a baseline. I thought it was unusual because the last time I did this same trip I got roughly 21mpg. I was a touch on the throttle on an open highway. Who knows. I'll take the extra fuel!
1 Post
I've caught the EPA website revising those estimates lower, they say it's because we drive faster now. Maybe so, but that doesn't mean a well maintained original car can't still do the old numbers at those speeds, and even then, many reported doing better than the window sticker EPA estimates. The EPA numbers have less than nothing to do with reality, they're all about political concerns.
Car: 89 Firebird
Engine: 355 TBI
I got 25.6 mpg on a long road trip with my L03 recently. Im sure now going from 2.73 to 3.73 im gonna lose some of that good gas mileage though.
Car: 86 Trans Am
Engine: 305 LB9
I was worried because I didn't want it to be lean lol
Usually half my trip takes half my tank of gas but I had barely used a quarter. Sounds good then. Also my car converter is just for show
1 Post
Just because 14.7:1 is best for emissions, and theoretically ideal, doesn't mean there's any worry, even at lean misfire. Only if it was that lean, then that hurts MPG.
Car: 86 Trans Am
Engine: 305 LB9
One of my friends cars burned a valve so I'm really cautious making sure fuel and air are correct
evilstuie
01-09-2020 08:29 PM
evilstuie
04-14-2016 08:52 PM
MoJoe
09-24-2015 09:12 PM
