Summit CD Ignition problem
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
i have ordered this kit: http://www.summitracing.com/int/part...2750/overview/
installed all like manual says, car starts and runs but it pops thru exhaust, the higher the RPM the more pops comes, sometime stops popping afrer about 3500-4000RPM, no idea what to do with it to make it run properly, any ideas?
best regards
best regards
Re: Summit CD Ignition problem
no body no idea on this issue ?
best regards
best regards
Was the car running fine before the install?
Have you triple checked the firing order?
How do the spark plugs look?
firing order as normal 18436572, checked whole system on two cars and same effect, spark plugs ok, when i tried to set timing it goes right ok to 19deg and then jumps to over 40deg, same effect on both cars, timing lamp is working ok.
best regards
best regards
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
This is just a hypothesis, but I wonder if your base timing is off. The ignition box fires multiple sparks below 3,000 RPM, and one spark above that. Could it be that the one spark event is close to the correct timing and one of the multiple events is not? Either way, they do have a tech support line for those boxes.
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Stupid question but, you do have the vacuum advance plugged when setting base timing, correct?
vacuum unplugged,
as for tech line, i'm from another side of the planet so it is quite hard to call
best regards
best regards
Car: 88 GTA "Cocaine"
Engine: 350 tpi
some of summits stuff is junk. return it and ask for another. they should be more than happy to help you. I bought an intake that had leaks all over it and they sent a box and sent me another
92camaroJoe
08-13-2015 06:07 AM
