5.0 V8 LG4 - Check out the chopped pipe on this photo - what does it do?
Car: 1985 TA http://bit.ly/1EadkbO
Engine: 5.0 V8 LG4 BBL
Transmission: 5 Speed Manual
And why is that paper there under the master cylinder?
https://www.flickr.com/photos/113572...57651948231432
FYI - This car starts and runs fine.
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
Re: 5.0 V8 LG4 - Check out the chopped pipe on this photo - what does it do?
that is Cable TV coaxle cable.... not factory lol and are you talking about the ID tag?
I'm not sure - in the top right hand of the picture you can see there is a piece of paper wedged between something below the master cylinder.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
The paper is under the connector for the brake pressure switch. It lights up the BRAKE light on your dash if it detects too great of a pressure difference between the front and rear brakes. Like if you blow a brake line. My 92 had the same thing on it. I think it's just an inspection tag from the factory. I removed it tossed it a long time ago.
colton_carlson
03-08-2019 12:21 PM
John Millican
02-25-2001 07:55 AM
