305 taller than 350?
Car: 1988 Firebird
So wrapping up my 350 to 305 swap I just used all old parts off 350 and so far everything has for perfectly was going to put y pipe to manifolds yesterday but the y pipe wouldn't reach the manifolds to bolt them together there was about a 3 inch gap, it looked perfectly aligned just not long enough y pipe it seems like. Weird thing is this was the y pipe that was on the 350 with the same manifolds I now have on my 305 but y pipe won't reach manifolds? Are the exhaust ports higher on a 305 compared to 350?
Car: 1988 Camaro
Re: 305 taller than 350?
Nope, all gen 1 sbc engines are small size (high, wide, long)
Car: 1988 Firebird
When I got the car the y pipe was in the trunk and the guy said he just took it off so I don't have a heat valve riser does anyone have a picture where their manifolds connect to y pipe?
Received 1,666 Likes
What kind of car are you working on?
If I may be so bold as to ask, why are you downgrading the motor?
Car: 1988 Firebird
88 firebird and the 350 was shot and I got the 305 free so that's why and I figured out I am missing the heat riser where do I get one of these my manifolds have 2 studs I can only seem to find 3 stud heat risers
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you might just have the wrong manifolds for that y pipe.
Car: 1988 Camaro
I have a 2 stud heat riser on a 1984 Z28 I'm parting out. If interested PM me
Car: 1988 Firebird
So thanks to knight rider 327 I realized I had a heat riser the whole time sitting in my parts pile, so now I need to bolt y pipe to manifold but I'm missing the nuts for the flange studs, really don't want to take off manifolds to find but size anyone know nut size for manifold to y pipe stud?
Car: 1988 Camaro
IIRC it's a common 3/8" - 16 thread, 9/16" wrenching.
Any hardware store, home depot, lowes, tractor supply, etc will have that size. About 15 cents each
Get stainless or brass ones. NOT just regular steel.
Won't matter much now; you'll be glad later on though.
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
I prefer brass as they won't gall and if you have a hard time with them coming off (highly unlikely), you won't break the stud!
