ignition timing 89 RS V6?
know this is the simplest question, what is the idle timing supposed to be set at? and is there an official service manual posted here somewhere that tells me this
now before someone says look under the hood, it's been replaced with an iroc hood that had a 5.7. Got to do a smog check and they have to check the timing
Re: ignition timing 89 RS V6?
https://www.thirdgen.org/forums/v6/6...iming-2-a.html
Here you go. Sometimes the toughest part is finding the timing connector.
Thanks, that's what I'm looking for.
could someone take a picture of their sticker on the hood, I'm afraid the guys at the smog shop will be baffled and not know what it should be timed at.
Ghettobird52
12-29-2023 08:23 AM
