Clean way to hook up electrical items to battery?
Between my FAST XFI system, MSD 6AL box, stereo amp, etc., I have several things that I have to hook up directly to my car's battery.
I bought these battery terminal connectors but it looks like a mess, and the bolts have to be tightened too frequently. I've attached a pic.
Does anyone know of a good, clean way to hook up your accessories?
Thanks!
Thanks!
You can for to a parts store and get something like the picture in the link. I would remove battery and mount it behind the battery on the back side of the headlights. That way all the wires are hidden. Only one power wire is seen running to the battery.
Link with picture
http://www.vte-europe.com/content/el.../12p_app_4.gif
Link with picture
Car: 1988 Camaro
Re: Clean way to hook up electrical items to battery?
I agree.. Use some type of junction box close to the battery. Run one 6, 8, or maybe 10 ga. wire from your battery to your junction, then hook everything to the junction
https://www.google.com/search?q=car+...r+junction+box
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
find a late 80's/early 90's Caprice cop car in a junkyard and get one of the underhood power distribution boxes from it... just follow the battery cables to a red plastic box on the fenderwell with 10mm stud with a self locking 15mm nut inside it and grab that.. should be bolted down with self tapping screws that take an 8mm socket.
i've also seen similar parts in pickups and what not, too..
Car: 1988 Camaro
junction boxes/power distribution boxes are great for this type of thing. I have 4 on my camaro.
I have one on my driver side kick panel for interior 12 volt acc. like aftermarket gauges, etc.
I have one 12 volt one on my rad. core support
I have one ran as a ground junction on the firewall as well as a 12 volt junction on the firewall
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
There already is a stock power junction block mounted next to the battery on my car.
I have added two aftermarket fans to it.
It is directly connected to the battery and is there to power items such as another power block/fans or anything with a heavy draw.
Most if not all Junction blocks are very hot at all times and I suggest removing both pos and negative battery cables before touching it.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
one method I have used in the past is a buss bar . they are used a lot on marine applications . check E bay , there are several that look nice and clean with covers . most boat/marine supply stores would also carry them . IMHO they work very well . just use a heavy gauge wire to power it . tap in where Ron USMC shows or battery and locate buss bar where you like . good luck ...
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Being in the jeep world, camaro world and bike world. I see a bunch of different ideas that are good and some that are bad.
Alot of the jeep guys run ALOT of lights and switches for everything. It creates a mess by the battery. So... alot of people run a water proof secondary fuse box. They are made by a company called " Blue seat systems"
Here is a write up that may help you. http://www.stu-offroad.com/electrica.../fuseblock.htm
https://www.bluesea.com/products/category/Fuse_Blocks
Street Lethal
04-30-2019 12:14 PM
BlackphantomZ28
08-22-2015 01:00 PM
db057
08-11-2015 10:11 PM
