starter problem!!! help!!
Car: 1988,1989 camaro
Engine: sbc 350 TBI
Transmission: 5 speed, th350 w/shift kit
Axle/Gears: 3:27
Im having issues with replacing my starter....first off it took me 3 starters at napa before they gave me one that matched my other one & acualy fit then as soon as i put it on it started the car fine about 3 shots then it started skiping on the flywheel so i thought i might of needed shims so i put some on then again started fine once then started skiping.....so next i looked up on it and someone told me to buy new bolts wich i did...but...again one start then she was skiping......any ideas??? Need help would realy apreciate it!! Starting to get nice weather and its driving me crazy!!! Haha
Car: 1988 Camaro
Re: starter problem!!! help!!
Sounds like the starter bolts to me. All bolts are not the same. The sbc has atleast 5 diff length bolts that I know of right off the top of my head. The bolts depends on the starter you use.
The starter bolts must have the knuckled shank.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Also a week battery will not allow it to engage the flex plate properly. It will not through or turn the pinion the way it should.
Engine: sbc 350 TBI
Axle/Gears: 3:27
Thanks for the reply! The battery in it is only about 3 weeks old and its a 800cca so i doubt thats the problem....i asked at a few parts stores and for some reason none of them can get bolts the only place i could fin some was at the dealer. Wich took 7 days to get and now that ive compared them they have about 1/4inch difference so ill go try to find some that will match my old ones....any sugestions other than dealer? Dont mind going there i just hate to have to wait another week
Received 1,666 Likes
What block EXACTLY are we working on here? (casting # only please... not "stock", not "4-bolt main", not "out of a Vette", casting number ONLY)
Car: 1988 Camaro
Yes giving use the block ID and starter part # will help.
Auto zone/advance auto has some starter bolts in stock on the rack with all the "help" brand parts
Engine: sbc 350 TBI
Axle/Gears: 3:27
Not sure im gona have to check tomorow i will let you know.....ran the serial # last year but i cant remember its a 350 tbi.....car was originaly a 305 tpi
Engine: sbc 350 TBI
Axle/Gears: 3:27
Im in new brunswick canada so no autozone for me.....napa is pretty much the biggest for parts supliers around here the rest is all smaller distributors....i might just end up having to buy some online
Engine: sbc 350 TBI
Axle/Gears: 3:27
Casting # on the block is 14093638
That block, being a late 80s and up one, will have the necessary hole.
Canadian Tire may well have the bolts. I just drive by one; didn't stop to look though.
Engine: sbc 350 TBI
Axle/Gears: 3:27
Only bolts they had at canadian tire was a pack of 3 and one was too small & the other 2 were about 1/4 inch too long
Engine: sbc 350 TBI
Axle/Gears: 3:27
What do you mean by necesary hole?
necessary hole = the hole you'll need so you can bolt up the starter for the 12.8" flywheel: the circled one in this pic.
Car: 1988 Camaro
There is quite a few diff length stock chevy starter bolts. It's based on the starter you are using.
The 96-00 vortec and the LT1 mini starters uses the Dorman number 678-107 4-5/16" or GM number 14097278 4-21/64"
Aftermarket mini starters uses either 3.7" or 4.45" long
Then with other full size factory starters you got units that use 1 long, and 1 short, or 2 longs, or 1 long and 1 med. length.
The length on those 3 bolts are 1-7/8", 3-5/8", 4-5/8"
Remember... NO WASHERS under the bolt heads. Starter uses the knuckled shank and larger dia. shank of bolts to index the starter to the block.
Engine: sbc 350 TBI
Axle/Gears: 3:27
The starter i bought is a napa premium starter....its 1 short bolt & one long one...i cant seem to find any bolts other than the ones i got at canadian tire wich were too long...
Car: 1988 Camaro
Hey just thought of this. I got a couple sets of factory starter bolts I can measure if needed and if you can't come up with anything I will let a set of these go for $5 + shipping
Engine: sbc 350 TBI
Axle/Gears: 3:27
I just got some bolts odered they should be in tomorow hopefully that will fix my problem....i still find it weird that just worn bolts would make it skip/grind that bad?....anyway i will let you guys know as soon as i try them out tomorow...thanks for the help!!
worn bolts
Car: 1988 Camaro
Yep what sofa said. My 1st go around with the vortec mini starter ended with failure due to the same prob. The vortec starters takes a touch shorter bolts, I didn't think much of it. Put a couple of washers under the bolt heads and tightened it up. Starter never sounded right, 300 miles later I was left with no start/no turning of engine, ground down teeth on flexplate and trashed starter.
Did a little research found the correct bolts, got new flexplate and new starter and been working fine since and that was about 7 years ago
Engine: sbc 350 TBI
Axle/Gears: 3:27
Well i finaly got my bolts and just like i suspected they dont fit....they thread in but there bot about 1/4 too long....at this point im geting pretty frustrated since ibhave no idea what to do next since i cant find the correct bolts anywhere.....any one have sugestions?
92camaroJoe
08-13-2015 06:07 AM
db057
08-11-2015 10:11 PM
