Help Please. Electrical or Fuelpump?
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
OK i have a
1992, Camaro RS 5.0
when i drive my car going about 40 to 65MPH
with nothing on, (AC/Heater/Radio etc)
runs fine.. BUT!!!!!
when i turn on my heater or ac(dont matter) and turn that fan speed to MAX
and im driving it my tacometer goes crazy and the car acts as if its going to die
and jerks BUT the second i turned it off goes back to normal driving.
HELP? im lost
1992, Camaro RS 5.0
HELP? im lost
Car: 88GTA
Engine: 5.7TPI
Re: Help Please. Electrical or Fuelpump?
OK i have a
1992, Camaro RS 5.0
HELP? im lost
1992, Camaro RS 5.0
HELP? im lost
My 88 GTA did that exact same thing years ago. Driving down the highway at 70 mph, hit the fan switch, felt like I dropped a cylinder, tach,volts, Oil Pressure gauges went crazy. Turn it off, all is fine.GM worked on it for a week and NEVER cured it.
What it was, was a bad ground for the heater motor. Run a separate ground wire from the heater motor ground to the ground strap on the firewall. Seems crazy, but it cured the problem.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Boy I waited YEARS to answer this question!!
are you saying to cut the ground wire n half, then ground the wire from plug to firewall or just open up the middle of the black wire and add a wire to it and ground it?...
Car: 88GTA
Engine: 5.7TPI
The red wire (which should've been black) with the yellow ring connector on motor, then to firewall
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
im gonna go to the junk yard an get a fan switch
and just replace it see if it changes anything, if it dont then i have not a clue
either..
either..
Received 1,662 Likes
It's not the fan switch.
Grounding remains a possibility though. Check very carefully and make sure the braided ground strap that connects the engine to the firewall, at the rear of the pass side head, is connected.
In fact you could just add another ground wire from engine to chassis somewhere convenient; such as, from the point where your negative battery cable is bolted to the block, to a nearby substantial body bolt or something similar. You can get a cable at a parts store that looks like a batt cable but has eye terminals at both ends that will work perfect for that.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
well the reason i have thought about changing the switch
there is a part on the control panel that i replaced due to a burn n melted mark on it..i went to the junk yard found a good piece replaced it and i no longer needed to smack the side of my dash to get the fan switch to work or come on sorta speak.
i did check the ground strap it is infact installed
every time i get out of the car tho i get shocked if i touch the car or anything metal after that.lol
i will add another ground to the chassis from the battery tomorrow n see what happens.. what a pain in the ***
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
well i replaced the switch and the relay switch
i noticed the 4 wires coming from the relay to plug type connector was melted
i cut the wires off n spliced them together. iv yet to drive it to test it ill post back after the test drive...
Car: 88GTA
Engine: 5.7TPI
The other area you need to look at it the High Speed Fan connector on the firewall right above the pass rear valve cover. That POS connector is bad news also!
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
damn car still acting like i originally posted about
only thing left is to find that red wire you keep talkin about
maybe its hidden in that plastic protective shell around the wires
or vacuum issue?
or egr?
or Throttle Position Sensor?
man talk about smacking my head against the wall lol
or vacuum issue?
or egr?
Car: 88GTA
Engine: 5.7TPI
This is that connector I was mentioning that is notorious for shorting out; it controls the High Speed Fan circuit.
The other "red" wire that you are looking for is that ground wire that I added. I mentioned I should have picked a BLACK piece of wire, but all I had at the time was red.
The issue you are having is definitely something in the fan circuit. Due to the fact that it starts acting up when you turn the AC/Heater Fan on.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
ya that picture is showing that connection near the heater hoses in the firewall
i see nothing like that. ill look again tonight an move that plastic shielding away n see if its just wrapped up
the engine was rebuilt so maybe moved down or left a bit
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
yea..i looked high n low in the tubing for that connection wires
and saw nothing..like that at all
my MAP sensor is in that place sorta speak
in the tubing for that connection wires and saw nothing..like that at all
But it doesn't matter. That's not "the" problem at hand, even though it's probably "a" problem, and is wasted to ashes, like everybody else's.
Did you add a ground cable from the engine block to the firewall or other convenient chassis point?
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
That's because it's not in the tubing. It's hanging out there, right out in the open.
Theres a ground strap from fire to engine block
and theres a ground from battery to fender
is it still necessary to add another ground ?
i have looked all around under the hood and i do not see that kind of connector at all.
just so yanno im not mechanically dumb i know my way around a car
so dont want ya to think "omg this guy is retarded lol" i just do not see that at all.
im been listing n looking hard for this..
can you suggest the possible locations on a 92 RS 25th anniversary edition for this red wire connection
also a question.?
when i bought the car it ran fine.no issues..
only thing iv done since i got the car was change spark plugs and spark plug wires. i have taken off the air filter cover completetly off a few times..checking for busted air lines n just looking at my stuff there.
could it be possible the coil is losing power when i have the fan on?
i know it sounds silly but..it only starts acting like its trouble shifting/advancing and tachometer is going crazy..but if i slide the ac to OFF
it all stops.and drives fine..
That connection doesn't matter. Don't worry about it.
Your problem is caused at a place where BOTH the blower motor power and the fuel pump, coil, etc. power pass through the same point. The one in question handles only the blower motor and therefore it is physically impossible for it to cause the symptom at hand.
However, just to answer the question, the connector in question is above the pass side valve cover, just below the windshield cowl. If you start at the purple wire from the blower motor and follow it, you will come to a plug with 5 wires in it, plugged into a small box; that's the blower motor high-speed relay. One of the other wires in that plug will be a big fat red one. Follow that wire toward the driver's side and you will come to the connector you're asking about. Assuming of course, that some PO hasn't hacked on the wiring some kind of way; a possibility that can never be completely discounted. And in fact, if the wiring has been altered, it's entirely possible that it was done in such a way as to make possible (or even unavoidable) what would have been impossible with the factory wiring. Needless to say, there's no way any of us out here could guess what kind of a hack job might have happened, so if that's the case, you're kinda on your own. You'll just have to examine every single wire and connection until you find the hack. None of us out here is going to know where that is or be able to see it for you.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
ill check the voltage with a meter when i get home i read that need to check the red wire and orange wire too..
i apreciate all the help it just really drving me crazy since it just started happening out of the blue lol
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
i might just for a temp solution is connect the heater blower motor to a toggle switch just so i CAN use the ac...110* weather in phoenix and no ac is umm hot..lol
I'd recommend against that.
One good hack job DOES NOT deserve another.
Odds are, hack jobs are already the cause of your problem. More hacking isn't likely to significantly improve the reliability of the car.
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
ok so, i took a chance went to auto zone, got a relay switch
installed it..drove car...BAM problem fixed...im so mad lol
i spent money on alt, battery, blower motor(needed that anyways), n junk yard parts 240$
i come to phoenix send 10$..an problem fixed...GRRRR
ty all for the help tho, it did help me locate issues i did fix
and for future ref later.....
Hey, sometimes yer the windshield, sometimes yer the bug...
Car: 92 Camaro RS
Engine: 5.0
Transmission: 700r
Update.
i was still stumbling, then i decided to install a ground strap and change the ground location for my 12inch sub amp ground wire..soon as i did that, my Volt meter went back up, all my gauges too came back to life as if it wasnt reading right..
moral of story ..i bet money hands down i didnt ground the amp correctly to much paint around the ground location..(/face palm)
car runs like a CHAMP,
Gunner242
12-25-2015 04:49 PM
TMZIrocZ350
10-07-2015 12:09 PM
