Coolant gauge seems to be inop or is it the sensor ?
1 Post
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Not getting a temp reading on the gauge but the Autoxray shows temperature readings..... My question is for a 1984 Trans Am, does the same sensor send data to the ECM and instrument gauge?
Thanks !
Chuck
Thanks !
Chuck
Received 1,664 Likes
Re: Coolant gauge seems to be inop or is it the sensor ?
2 completely separate sensors.
The gauge one is in the driver's side head between the #1 & #3 spark plugs. Should have a green wire plugged onto it.
1 Post
Thought it would be 2 sensors..
Cool...I'll check that ... I thought that sensor between 1 and 3 was for the fan?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the sensor between 1 and 3 is the gauge wire... test it by turning the key on and grounding the wire: it should make the gauge instantly max out... if it does make the needle jump, then buy a new sensor and put it in.. they are cheap.. if it doesn't move the needle, trace the wire and figure out what the problem is.
1 Post
Switch for the fan is in the same place in the other head; between #6 & #8 plugs.
Glowsock
09-06-2015 06:40 AM
