ac vacuum lines
Car: 84 Z28 camaro
Engine: 383 stroker
Transmission: turbo 350
ac vacuum lines
I want to put ac in my car but my problem is when I put it on vent or ac it doesn't blow out the vent. Where do I start to look for problems. Any help greatly appreciated.
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Re: ac vacuum lines
There are two small vac lines that come out of the hvac harness u need to hook one up to part vac and the other to full vac if it doesnt still come out when u have them hooked up switch them and it should work
Car: 84 Z28 camaro
Engine: 383 stroker
Re: ac vacuum lines
Thanks, so I'm assuming they are on the passenger side of the car.
1 Post
Re: ac vacuum lines
One is hooked up to the diverter valve on the heater core hose the other u can see it runs to the back of the hsr plenum hope this helps out
Car: 84 Z28 camaro
Engine: 383 stroker
Re: ac vacuum lines
Yes, that helps alot, but I only see one hard line coming from the harness. I also discovered that I have a vacuum line not hooked up coming from the climate control switch, the violet color line is broke about 5 inches from the switch. I can't find where it comes from under the dash. Would this be my problem?
Doobie52
09-11-2015 06:19 PM
